tranny problem.. pulled codes.. now what?
P0732
gear ratio error
P0781
1:2 shift error
P1670
No EF feedback -Not exactly sure what the original wording was since my friend wrote it down for me while I was working.
The trucks a 03 with 96000 miles on it, stock trans.
0781 1-2 shift malfunction
1670 EF feedback signal not detected.
The tests for the 1670 also reference a 1316 code (the dreaded UVCH one)
P0782, P0732, P0733 a SSA, SSB or Internal Transmission Components 2-3 shift error. Engine rpm drop not detected when 2-3 shift was commanded by PCM. Incorrect gear selection depending on failure mode and transmission range selector lever position. Refer to the Solenoid Operation Chart. Shift errors may also be due to other internal transmission concerns such as stuck valves or damaged friction material. May flash TCIL.
P0781, P0731 a SSA, SSB or Internal Transmission Components 1-2 shift error. Engine rpm drop not detected when 1-2 shift was commanded by PCM. Incorrect gear selection depending on failure mode and transmission range selector lever position. Refer to the Solenoid Operation Chart. Shift errors may also be due to other internal transmission concerns such as stuck valves or damaged friction material. May flash TCIL.
Unless you've got some damaged wiring or connectors, It's probably time to visit a tranny shop. It sounds like it might be internal.
The 1670 doesn't seem to fit what you describe. Do you have any issues other than the shifting? Maybe clear the codes and try to read them again after some more driving.
Ill clear the codes and see if UVCH code goes away...if not well I have a extra set of pennie glow plugs that I might as well throw in there...
Thats what I would love to do, its still under warranty thought.....
Im goin to try to scrape up the funds for the BTS so I never have to worry about it.
I have this attitude about spending more than average on whatever product I am currently in the process of buying.
I buy whatever is best to answer the need without regard for what it costs because I know in six months after the money is spent, I won't miss the money spent, but if I don't get the exact thing that I think is the best for the job, then I will regret the decision and wish that I had spent the extra money for the thing that I really wanted in the first place.
I've done the "wrong thing" more than once. The last go-round was over my injectors. I thought that getting a set of rebuilts would do the trick for clearing up some knocking noises that I was hearing that made me worry about an injector tip getting ready to break off. The set of rebuilts cured that problem, but the innard on several of them were in worst shape than the ones that I turned in as core and the truck ran worst than before, but sounded less harsh. Not acceptable in my book, but I had made the purchase and they worked so I really couldn't just send them back. They worked.
But for a year I had to put up with a fluttering miss at 5% throttle until I got fed up with it and bought a new set of Alliants and put them in.
That is what I should have done in the first place! Spend the extra $1000.00 on the new injectors and now the truck runs better than the day it came off the showroom floor. Eight brand new injectors getting fed plenty of air-free fuel due to the fuel pump mounted in the tank with no more mixing chamber or quick connects.
CLICK HERE FOR VIDEO It goes pretty good for a 10,000lb truck using only stock tune.
Anyway, I know that I am telling you how to spend your money, but consider what I have said. Brian makes one of the best trannies on the planet and backs it up with a great warrenty, and is reachable. (Meaning he calls you back real soon if he doesn't answer the phone right away.) That alone is worth a lot. And he and Jody Tipton know how to work with each other.
Since Im 18, alomst 19 and still live with my parents they dont think it would be the best way to go if its still under warranty...I have the money in my savings account for the BTS but they wont let me use that ...Im working on them since Ive been workin since Iwas 12 and the money is mostly mine that Ive worked for, other than what my grandma gave me before she passed.
I dont want anything other than a BTS in my truck, and Ill convice my parents soon enough.......hopfully lol
EDIT: Brians customer service is 1/2 the reason I want to go with him...you dont get that anymore.
I understand what you guys were sayin though and thanks for the advice I understand why you would say all that and I dont want to come across in a bad way...
Have you figured out what caused your tranny problems to begin with? This would probably be good information to share with Brian.
may have had something to do with it. Make sure the guys over at BTS know exactly how much you want out of your truck so they can give you a tranny you'll be happy with.From what I've heard theres a difference in having a chipped truck and having Jody's 140 aggressive tune. Nothing's indestructible if you try hard enough. I was thinking you might have been getting on it in 140 when you started to notice something different. If that's the case, that would be good info to share. As mentioned above, Jody & Brian are known to work well together.
