Transmission dead!!!! pulled codes finally!!
Old Sep 2, 2007 | 10:08 PM
bigpowerstroke's Avatar
bigpowerstroke
Thumbs down Transmission dead!!!! pulled codes finally!!
Well, a week ago my transmission finally gave in. Started to act very funny and finally lost overdrive.
I was having a little trouble with it shifting from first to second but after a few days first to second was fine and I had no overdrive.
Here are the codes
P0733 - gear three ratio error
P0743 - torque converter system electrical failure
P0475 - pressure control solinoid error
P0470 - exhaust backpressure sensor error
P0782 - transmission control sys. electrical
P0781 - 1-2 shift error
P0732 - gear two ratio error
What is the cause of my prolem? Is the transmission toast??
Old Sep 2, 2007 | 10:27 PM
Lead Head's Avatar
Lead Head
I'm no expert, but maybe you should check for corrosion and lose wires going to the transmission
Old Sep 2, 2007 | 10:52 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Well, I will have to look this up tomorrow on the shop DVD at work. I would say it does not look good. Tranny pump maybe? How many miles on the rig?
Old Sep 2, 2007 | 11:27 PM
bigpowerstroke
I just went passed the 100,000 mile mark. About 101,000 miles or so.
Old Sep 2, 2007 | 11:33 PM
Tenn01PSD350
Many have survived longer than that. I will try to make a point to look in the AM for the codes on the manual. Be advised, the tranny does not often throw BS codes. My first step with my AE would be to clear them and check the wiring and connections, but I would bet the ones I could clear would return.
Old Sep 2, 2007 | 11:55 PM
bigpowerstroke
will do... any certain areas to check on the wiring other than directly on the tranny?
Old Sep 3, 2007 | 10:57 AM
Tenn01PSD350
I will be the first to say I am not a tranny expert. I would hope that you can find an electrical problem to repair. Other than that, it looks like a fluid pressure issue may be the culprit. Someone else will have to chime in here hopefully. Is it the same/original fluid? What does it look and smell like?
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH vAlign=bottom align=middle>Fault Code </TH><TH vAlign=bottom align=middle>Refer to Footnote </TH><TH vAlign=bottom align=middle>Circuit Index </TH><TH vAlign=bottom align=middle>Condition Description </TH><TH vAlign=bottom align=middle>Probable Causes </TH></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TD vAlign=top align=middle>P0732 </TD><TD vAlign=top align=middle>— </TD><TD vAlign=top align=middle>GRV </TD><TD vAlign=top align=left>Gear 2 incorrect ratio </TD><TD vAlign=top align=left>Mechanical/hydraulic failure, 4x4 switch failure </TD></TR><TR><TD vAlign=top align=middle>P0733 </TD><TD vAlign=top align=middle>— </TD><TD vAlign=top align=middle>GRV </TD><TD vAlign=top align=left>Gear 3 incorrect ratio </TD><TD vAlign=top align=left>Mechanical/hydraulic failure, 4x4 switch failure </TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TD vAlign=top align=middle>P0781 </TD><TD vAlign=top align=middle>c </TD><TD vAlign=top align=middle>— </TD><TD vAlign=top align=left>1-2 Shift malfunction </TD><TD vAlign=top align=left>Circuit failure, faulty solenoid, faulty clutch, PCM </TD></TR><TR><TD vAlign=top align=middle>P0782 </TD><TD vAlign=top align=middle>c </TD><TD vAlign=top align=middle>— </TD><TD vAlign=top align=left>2-3 Shift malfunction </TD><TD vAlign=top align=left>Circuit failure, faulty solenoid, faulty clutch, PCM </TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TD vAlign=top align=middle>P0743 </TD><TD vAlign=top align=middle>b, c </TD><TD vAlign=top align=middle>TCC </TD><TD vAlign=top align=left>Torque converter clutch system electrical </TD><TD vAlign=top align=left>Faulty solenoid, circuit, PCM </TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TD vAlign=top align=middle>P0475 </TD><TD vAlign=top align=middle>b </TD><TD vAlign=top align=middle>EPR </TD><TD vAlign=top align=left>Exhaust pressure control valve malfunction </TD><TD vAlign=top align=left>Open/grounded ckt., solenoid open/shorted, failed PCM </TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TD vAlign=top align=middle>P0470 </TD><TD vAlign=top align=middle>— </TD><TD vAlign=top align=middle>EBP </TD><TD vAlign=top align=left>Exhaust back pressure sensor circuit malfunction </TD><TD vAlign=top align=left>Biased sensor, open signal return </TD></TR></TBODY></TABLE>
b MIL (OBDII) illuminates after second consecutive fault.
c Transmission control indicator (TCIL) flashes when fault is present.
Old Sep 3, 2007 | 02:46 PM
bigpowerstroke
I have serviced the tranny about 4 times. Flushed it once. I haven't had the chance to check and see what it looks like now. I've been back and forth from my home town to school and the truck has been sitting for a week now. I will get back with some more information soon.
Thanks for your help.
DRRXR
Oct 30, 2016 01:22 PM
richierand95
Aug 16, 2016 07:51 PM
Tysoid3317
Aug 15, 2012 02:48 PM
ace33172
Jun 12, 2011 08:05 AM
01silvergt
Jul 13, 2005 02:08 PM
