Shifting into Reverse Problem
Old Feb 7, 2006 | 02:04 PM
mtsnieg's Avatar
mtsnieg
I have a '91 F350 Supercab 7.3 IDI with a 5 speed manual. When I shift into reverse it grinds and doesn't seem to 'slip' into gear like others. Then if I used a light pedal I move back. If I gun it just a tad it'll slip out of reverse unless I hold the shifter. But if I put er in first and creep foreward a foot it won't gring goiung into reverse, but other symptoms still happen. The only tranny work I've done is replacing them or a clutch, so I'm not knowing what's wrong. Thanks.....Matt
Old Feb 8, 2006 | 08:13 PM
mtsnieg's Avatar
mtsnieg
Anyone????
Old Feb 11, 2006 | 10:50 AM
mtsnieg's Avatar
mtsnieg
Bump to the top.
Old Feb 11, 2006 | 05:39 PM
wickymustang's Avatar
wickymustang
Reverse is usually not synchronized, if there is grind going into reverse your clutch is not properly set up. As for the other symptoms either your clutch or the clutch teeth on the gear/blocking ring are shot and need replacement.
Old Nov 19, 2023 | 11:41 AM
GaRivers's Avatar
GaRivers
2nd Gear
Where is the gear/blocking ring located may I ask plz
On a 1989 Ford f150 4x4 straight 6
Old Nov 20, 2023 | 04:52 AM
tjc transport's Avatar
tjc transport
i ain't rite
almost 18 year old thread, and he has not logged on in over 14 years.
Old Nov 20, 2023 | 07:31 AM
tecgod13's Avatar
tecgod13
True but he wasn't asking the OP anything...
Gear/blocking rings are internal to the transmission. Each gear in a manual transmission has a second set of 'teeth' that mesh with a sliding collar/ring that also is meshed to the shaft the gear is turns on.
Transmission needs to be pulled out and torn down to inspect and replace those parts.
Automatic transmissions are a whole different animal.
Old Nov 20, 2023 | 09:56 AM
tjc transport
i ain't rite
Actually he was. He Quoted someone that has not logged on in 14 years
that usually means he was asking that person
Fordx4jake
34
Apr 24, 2014 11:53 AM
Wild-Bill
Dec 12, 2013 05:56 AM
Wish9955
1997 - 2003 F150
Mar 28, 2013 07:58 AM
Neal 97 250
Oct 12, 2008 10:48 AM
Country705
Feb 11, 2007 08:45 AM
