strange problem need advice????
Old Feb 10, 2007 | 05:06 PM
Country705's Avatar
Country705
Okay guys i got a 1994 ford f150 with a 300I6 and a 5spd tranny. My only problem is that when my truck is on a incline it doesnt want to go in reverse whatsoever but if the truck is level it goes into reverse no problems. what do you guys think this is. I have been told it could be the yoke or maybe reverse is going out.
sincerly,
John T.
Old Feb 10, 2007 | 07:18 PM
Phillip Guidry's Avatar
Phillip Guidry
Did you try letting the clutch out in neutral then repressing the clutch and trying to shift into reverse? On every manual shift I,ve owned I had to do that very now and then.
Phil
Old Feb 10, 2007 | 07:33 PM
F250BgRd's Avatar
F250BgRd
You also might want to try putting it into first before you put it in reverse.
Old Feb 10, 2007 | 07:36 PM
Country705's Avatar
Country705
tried both of those no go it goes into reverse but as soon as i let up off the clutch it jumps out of reverse.
Old Feb 10, 2007 | 07:39 PM
Country705's Avatar
Country705
the baffling part is that this only happens when the truck is on a incline
Old Feb 10, 2007 | 07:42 PM
Redcat Diesel's Avatar
Redcat Diesel
I'm not real familiar with light duty 5 speeds but it sounds like a problem with a shift bar or yoke.The weight of the sliding gear may be pulling the reverse bar out of alignment with the other shift bars.I've heard of this problem before but never heard the cause.
Old Feb 11, 2007 | 08:45 AM
loepke72's Avatar
loepke72
Most likely a worn 5/R synchro and reverse speed gear. Pretty common problem with the M5OD.
