Help decoding EEC results
Old Jan 27, 2006 | 03:00 PM
Ogriv's Avatar
Ogriv
Question Help decoding EEC results
I have an 87 F150 with 300ci I6. It seems to be running well, but the mpg are a little low (16 highway, 10 city). So I thought I would follow the instructions from fordfuelinjection,com to read the memory. I connected my DVM, with continuity check selected, and turned on the key (not the engine). I received a series of beeps. I got some paper and jotted down the beeps.
(A 1 signifies a beep, a space indicates a pause)
111111 1111111 111111 1111111 1 111 11 111 11
So I assumed this meant 67, 67, 32, 32
So according to the chart,
67 = Neutral Safety Switch Failure
32 = EVP circuit below minimum voltage of 0.24 volts
Is this correct? If so, what the heck is the EVP ?
Thanks
Old Jan 27, 2006 | 03:20 PM
lenny1carl's Avatar
lenny1carl
evp is EGR Vacuum Position sensor. its mounted on top of the egr valve. it monitors the position of the egr stem, how open it is
Old Jan 27, 2006 | 09:23 PM
Ogriv's Avatar
Ogriv
Am I decoding the beeps correctly?
Old Jan 27, 2006 | 09:46 PM
thomadm's Avatar
thomadm
yes. Try testing the EVP, otherwise id say its a goner, real easy to replace.
Old Jan 27, 2006 | 10:12 PM
Ogriv's Avatar
Ogriv
Any clue as to what effects this would have on the performance of the engine?
greatone111
2004 - 2008 F150
13
Jan 9, 2020 08:58 PM
wicat3
20
Aug 28, 2012 06:16 AM
keating
Jun 8, 2009 07:32 AM
shipper
May 3, 2008 03:43 PM
bluene
Oct 9, 2005 12:28 PM
