EVP Sensor
Old Oct 9, 2005 | 10:17 AM
bluene's Avatar
bluene
EVP Sensor
My 1989 F250 with 460 motor has 110K miles. Checking KOEO codes I get a code 32 --- EVP circuit below minimum voltage of 0.24 volts. I put in a new EVP from Advance Auto and I don't get the code 32 any more but I get a code 34 --- PFE or EVP circuit above the closed limit of 0.67 volts. I put the old one back in and just get the code 32 again. The codes just show up on the stored codes. I get only 11 at first. I clear the codes between each test. Do you suppose they gave me the wrong unit, or is there something else wrong?
Old Oct 9, 2005 | 12:11 PM
MemOrex's Avatar
MemOrex
There are 2 EVP's for these trucks. One is black and the other is gray. Make sure you got the same colored one as your old one.
Old Oct 9, 2005 | 12:28 PM
bluene's Avatar
bluene
Oh! Thanks. I got a black one, and my old one is sort of white -- maybe it's gray. I'll see if I can get one of the same color.
ceej4801
120
Sep 20, 2016 07:51 PM
icantdo55
Jan 29, 2014 07:11 PM
cornstar6207
Mar 15, 2012 08:22 PM
MemOrex
80
May 29, 2008 09:04 PM
TrucksNamed"PHIL"
Apr 1, 2007 08:58 PM
