Chug Chug Chug - During Acceleration
Old Jun 7, 2009 | 10:36 AM
keating's Avatar
keating
1995 - F150 - 8 Cyl 5.0 EFI - Mannual 5 Speed -
Just Changed The Fuel Filter And The TPS ,
Was Running Ok The First Day , Now I Get Chug Chug Only During Moderate To Heavy Acceleration,
Smooth Combustion At Constant Speed.
Also The Tachometer Seems To Dip Down A Hair Intermittently At Idle.
Fuel Pump ?
I Did A Self Test And Got - 111/111 (KOEO) And 111/111 (CM)
Checked The Distributor Cap And Contact Points Along With All Connections,Wires And Plugs ( Plugs And Wires Are Old And Due ).
Can't Hear Any Vacuum Leaks And The Fuel Line Checks Out All The Way.
Any And All Help Is Welcome,
Thanks In Advance.
KEATING
Old Jun 7, 2009 | 04:22 PM
Bulkride's Avatar
Bulkride
1995 F-150
5 Speed
302
keating I chased the same problem for months. Took all the steps as you have and your doing a good job. Just stick with it. My case was:
Fule pump
I was told to check the fuel pressure at idle and then under load. Be carefull and you'll need help checking it under a load, but the fuel pressure dropped.
I changed the pump and its ran perfect ever since.
Let me know if theres any thing else.
Old Jun 7, 2009 | 09:13 PM
keating's Avatar
keating
Is There A Pump In Both Tanks ( Two Tank System ) ?
If So Are They Interchangeable ( Rear Tank Leaks , I Don't Use It ) ?
Thanks
Old Jun 8, 2009 | 07:32 AM
keating's Avatar
keating
Now I'm Reading That I Need A Special Tool To Change/Remove The Fuel Pump And That Going To A Garage Might Be Cheaper Than Doing It Myself ?
keating
Sep 18, 2010 08:52 PM
handykeith29
May 30, 2008 06:04 AM
Meanie
Apr 12, 2006 10:29 PM
Keats
Aerostar
Mar 28, 2006 05:28 PM
