Starter replacement
Old Jan 25, 2006 | 07:06 PM
jqp00002's Avatar
jqp00002
Starter replacement
Anybody have a suggestion on getting to the top bolt on the starter of a 1991 7.3? I was looking at it this evening and could even see it to get a wrench on it.
Old Jan 25, 2006 | 07:30 PM
trike1946's Avatar
trike1946
Use a long extension with a socket. It should work fine.
Old Jan 25, 2006 | 07:35 PM
jqp00002's Avatar
jqp00002
The problem I have is the getting to it. I made an attempt but the problem is there is no room between the starter housing and frame to work the ratchet.
Old Jan 25, 2006 | 08:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Dunno how much different the frames are between the 91 an 01, but on my tuck the only "easy" way to access the top bolt is with a 17mm open end wrench. There is just enough room to get about 1/4 turn per throw on it. As long as I leave the bottom two bolts tight, the top one thread out pretty easily by hand once the torque is broken on it.
Old Jan 25, 2006 | 08:51 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Depends on which starter you have.
I have always had a Mitsubishi gear reduction starter on mine.
Over the years I have seen four different styles of the same starter.
How you get at the top bolt is different for each one.
I have never done a Delco direct drive starter.
You have to feel the top bolt, if you get to where you can see it you will not be able to get your arm to it.
Old Jan 25, 2006 | 10:15 PM
turfmaster's Avatar
turfmaster
use a 1/2 inch socket with a quarter drive ratchet and an extension longer than the starter just did mine yesterday
Old Jan 26, 2006 | 12:10 AM
roamer37's Avatar
roamer37
I just change one on my 94 turbo and it was a piece of cake just use a 3/8 flex ratchet a 10 inch ext and a 1/2" or 13mm flex socket
Old Jan 26, 2006 | 12:29 AM
PLC7.3's Avatar
PLC7.3
If you run you finger over the top where the starter attaches you can feel the top bolt, then with a wobble (15*) extension and the right socket, you can undo it by feeling the socket and guiding it to the bolt.
Old Jan 26, 2006 | 12:35 AM
roamer37's Avatar
roamer37
Just watch it when it comes loose its heavy
Old Jan 29, 2006 | 08:01 AM
jqp00002's Avatar
jqp00002
Thumbs up
Thanks for your help. I got it out and the new one in and it starts likes crazy. It took some time and a few choice words. I found that 2 inch extention a wooble joint and then a 6 inch extension did the trick. I also used an air ratchet to speed up the process. But again thanks for all of your suggestions.
Old Jan 29, 2006 | 10:22 AM
CF-DRG's Avatar
CF-DRG
Just curious, what did you do with the old starter???
Old Jan 29, 2006 | 12:56 PM
jqp00002's Avatar
jqp00002
I took it back to the parts store for the core deposit.
Old Jan 29, 2006 | 09:41 PM
CF-DRG's Avatar
CF-DRG
Just asked, because I kept my old one and rebuilt it.. Very easy to rebuild (usually just brushes and maybe bearings $20-30 sometimes a solinoid) and then you have spare.. Food for thought next time one goes....
Old Jan 29, 2006 | 10:36 PM
PLC7.3's Avatar
PLC7.3
Gees last time iwas going to do it prices were much higher........
WIL 48-27-9154 starter repair kit $65.90 CDN +tax
WIL 60-27-15062 Solenoid switch $37.00
Phil Woolfson
Jul 9, 2014 08:15 AM
Speedman_1026
Apr 13, 2014 04:40 PM
AZRRC
Jan 21, 2014 12:11 PM
Crossbones5
May 18, 2012 07:54 PM
KJKozak2
Jan 12, 2004 09:25 AM
