Help continuous running starter
Old Jul 7, 2014 | 09:23 PM
Phil Woolfson's Avatar
Phil Woolfson
As soon as it gets battery, even with ign switch off, starter is running and remains running. Is this starter solenoid (fender wall) or the starter itself?
(1989 460 / C6 4X4) This just started today, after the Miata wound up in the shop... I first suspected the ignition actuator, but I pulled the wheel and it was fine. Put it all back together, When I reconnected the battery, key off, the starter was running, no FP at the rail, just cranked. With the key on, it started right up, 40ish psi, so I am not suspecting anything in the ignition circuit...
Old Jul 8, 2014 | 02:50 AM
87 XLT's Avatar
87 XLT
The red/blue stripe wire connects 12 volts from the ignition switch to the starter relay. Pull the wire off of the relay & see if it still cranks.
Old Jul 8, 2014 | 09:45 AM
Phil Woolfson
Yep, It was the solenoid. It's a symptom... The 2 possibilities are that the starter has worn bearings that don't like turning when warm, or the possibility my new rebuilt dist. has a bum stator. I can get a brand new starter from Napa for $80. The sound when trying to start hot is like something is really resisting rotation, the engine oil level is fine and it is just a couple of months old.
Old Jul 9, 2014 | 08:15 AM
The other Joe's Avatar
The other Joe
Just had that happen to my Landcruiser yesterday.
Fwiw, I take my starters to a local rebuilder who does a much better job with better quality parts than the cheap rebuilds and China crap out there.
Roller150
20
Aug 4, 2015 10:28 PM
cfassett87
Jun 25, 2012 08:49 AM
Bundy4825
Jan 29, 2012 05:33 PM
johnwilkman
Electrical Systems/Wiring
Feb 13, 2009 01:16 PM
dwoxford
Dec 2, 2004 06:17 PM
