78 F100 Ignition Problem
Old Jan 24, 2006 | 02:43 PM
OLDTRUCKMAN's Avatar
OLDTRUCKMAN
I Own A 78 F100 Truck. 351m Engine Automatic Transmission. I Have Replaced Fuel Pump, Fuel Filter, Engine Module, Ignition Switch, And Key Cylinder. My Truck Has A Push Button Installed From The Previous Owner For The Starter. I Want To Make It Work With The Key Switch. How Can I Fix This Problem. I Thought New Switch Or Engine Module Would Work. I Have Even Tried A New Solenoid, Still No Luck. Any Thoughts
Old Jan 24, 2006 | 02:51 PM
IBeam's Avatar
IBeam
Neutral Safety. Unless he run the wires direct to the solenoid on the fender well, they spliced into the harness somewhere. Chances are the original problem for the push button was to by pass the Neutral Safety switch, and they did not know how to trouble shoot it, and the bypass was easier.
Trace the wires from the push button first and see how they done it. If it is spliced into the harness, they had to have a hot supply then they spliced into the wire in the harness going through the firewall. Undo this splice, then reconnect the wires. If this does not get it working, then check the neuteral Safey switch. I assume it is a C6 Trans, it should be mounted to the Trans where the Shifter shaft and linkage attach. It will have a small wire harness and plug. I forget the pin out on this, but maybe someone else can tell you, but you can by-pass the switch with a jumper to test it. There should only be 4 wires, two for Neuteral Safety, and two for reverse lights.
Old Jan 24, 2006 | 02:53 PM
Mil1ion's Avatar
Mil1ion
How about coming down to the related truck forum?
The 73-79 truck forum.
We could have saved you from buying all those parts
This forum is for General automotive questions that Don't already have a forum for them
Old Jan 24, 2006 | 05:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Jan 24, 2006 | 05:18 PM
Mil1ion's Avatar
Mil1ion
Eric please merge yours & Ibeams posts to this other thread
https://www.ford-trucks.com/forums/s...d.php?t=453957
Old Jan 24, 2006 | 08:44 PM
MR_J_DAHMER's Avatar
MR_J_DAHMER
Push Button Start
People do this modifaction because they are lazy or have bad troubleshooting skills. Return the trucks wiring to original as posted earlier. It could be something as easy as a miss adjusted ignition switch, neutral saftey switch, or more serious steering collum rod and rack problem. Do u have tilt wheel? Makes a difference in parts. GOOD LUCK HUNTING DAHMER
Old Jan 24, 2006 | 09:22 PM
Mil1ion's Avatar
Mil1ion
No column rod from the ignition switch in this year.
That came in the 80's.
The switch he has is on the dash.
Old Jan 26, 2006 | 01:17 AM
MR_J_DAHMER
Brain Fade
I think i am stuck in the 80's, hair cut, music,wife,,sorry for the brain fade,,DAHMER
Old Jan 26, 2006 | 07:50 AM
User 71024's Avatar
User 71024
Some of us OLD GUYS just Like buttons it reminds us of our yute
'78F250351m
Mar 4, 2015 08:32 PM
78bigunns
Sep 24, 2014 05:50 PM
fordnurse
Jul 22, 2013 03:37 PM
spinach
Sep 12, 2009 11:26 AM
dcollier
Mar 13, 2006 12:28 AM
