87 F250, 460, we can jump the solenoid to start, but the key switch doesn't work. Tried new key switch, ign. switch, and solenoid, nadaa. Would a bad ignition module cause it to not turn over?? It is mounted on the distributor. Thanks for any ideas.
No the ignition module will not cause it not turn over.
More than likely you have a bad P/N switch down on the side of the transmission or with the clutch peddle.
If the actuator rod is not pushing the tab on the ignition module it won't turn over. If the ignition module is bad I doubt that it would turn over with the key.
Try jumping from the small trigger wire's post to the hot terminal on the solenoid coming from the battery.
If it clicks and turns over it's the ignition switch, if nothing happens it is the solenoid.
Do you have a tilt column? Are you sure the actuator rod is moving the switch?
Did you try adjusting the ignition switch's position -up- on the column.
My 87 auto tranny had the same problem. All I had to do was adjust linkage on tranny and the column so the P/N switch knew the truck was in park. I guess over time these things get out of adjustment.
The way I found out I needed to do the adjustment was I pulled the gear shift handle up while the truck was in park and it the key started the truck.
Yes it does have tilt, and the rod is moving the ign. switch, so I don't think that is the problem. It is an automatic, and the pickup has been setting for about 3-4 months. We also replaced the solenoid and that didn't help.
88 150 w/manual&straight 6.Had nothing but SUPER drain of electricity, put in selonoid, no start, but jumping across poles now turns over. Gauges are screwey. any ideas where to go 1st?
