B&M floor shifter
Old Jan 17, 2006 | 03:31 PM
76 F-150 390FE's Avatar
76 F-150 390FE
B&M floor shifter
im getting tired of not getting the right gear on the column shifter so i decided to go with a floor shifter, im looking at getting the B&M StarShift. has anyone here put a floor shifter in one of these trucks? also has anyone had any experiance with a StarShift?
Old Jan 17, 2006 | 03:58 PM
30over's Avatar
30over
Hello, I've had a B&M Star Shifter before. They are good shifters and work well but, you will be much happier with a B&M Light Truck Mega Shifter. They work about the same but, the Light Truck Mega shifter has a much taller base for a truck which looks better and is more comfortable to use. These are really easy to hook up and work really smooth with cable opertation. They have a lighted indicator, reverse lockout, neutral safety switch, and backup light switch hookups. They come with a whole pack full of extra brackets for about any transmission on the planet, so you can use it in about any vehicle or transmission you choose.
You can look in my gallery for a side view. After my column screwed up for the second time, I was over it and went to the Light Truck Mega Shifter and never looked back. Most good perfomance shops sell them. Summit Racing would be a good place to pick one up too.
Good Luck!!
Old Jan 17, 2006 | 04:12 PM
76 F-150 390FE
i am not too concernd with the height of it, i went out in my truck with a tape measure and something to act as the grip and put it at about 12 inches and it felt fine for shifting, now if it was a manaul there would be a problem but it is fine, plus i like that you can go from detent to ratchet and have some fun. also the truck mega shifter is a bit more expensive than the starshifter and i have limited money and i need to fix my exhaust manifolds also. the main reason i am getting this is because i dont have a neutral saftey switch or back up light switch and this comes with them and i am really getting sick of being in neutral thinking im in reverse.
Old Jan 17, 2006 | 10:17 PM
30over's Avatar
30over
I can understand that. I had a Star Shifter in a 66 Cheby Truck with a 396 and Turbo 400 once. It worked really well and took a lot of abuse. Yea, they are a good bit cheaper. I'd say you'd be happy with one.
There's a new one on ebay right now with a buy it now and free shipping for $119. The item number is 8030126747. I don't know if that's a good price or not, but it might be.
Good Luck!!
Old Jan 17, 2006 | 10:48 PM
76 F-150 390FE
actaully that is about $40 cheaper than ordering it from summit like i was going to, i dont have an e-bay account but their web site said i can call them to order so ill do that, thanks for finding that.
Old Jan 17, 2006 | 11:01 PM
30over's Avatar
30over
You Bet!! You'll be banging through the gears in know time!!
Old Jan 23, 2006 | 01:16 AM
GeneStoner's Avatar
GeneStoner
Do yoursef a favor, spend the extra few dollars and get the Truck Megashifter. You may not think its a big deal now, but you will.
Old Jan 23, 2006 | 08:54 AM
tomcasino's Avatar
tomcasino
I put a Hurst uni-matic shifter in my '75 F250. Since it's cable operated, you can mount it anywhere. I got it from Summit Racing.
Old Mar 10, 2006 | 02:37 PM
countryF150's Avatar
countryF150
I was looking at putting the Hurst truck shifter in my 79' f250 4x4 w/400. All of these types say up to 78', i was wondering if it would still be fine or what i would have to do. Thanks
http://cgi.ebay.com/ebaymotors/NEW-H...QQcmdZViewItem
Old Mar 10, 2006 | 02:59 PM
chet_cowan's Avatar
chet_cowan
thats a shifter for a manual tranny you posted the link to. Just makin sure you know that before you order. It should be fine for a '79 though.
Old Mar 10, 2006 | 03:05 PM
76 F-150 390FE
that aint the sifter you want, that is to replace the three on the tree manual shifter. you want a auto shifter. http://www.hurst-shifters.com/Produc...minselection=1 those are the ones for auto trannys
TrippingCobras
Jun 28, 2012 09:37 PM
1981 F_100
Mar 2, 2011 07:00 AM
chiaml
May 4, 2009 11:00 AM
Pappys53
Jan 21, 2009 02:49 PM
DRanchero
Feb 11, 2005 11:09 PM
