Automatic floor shifter?
Old Mar 1, 2011 | 07:58 PM
1981 F_100's Avatar
1981 F_100
Has anyone converted the colum shifter to a floor shifter? What would be the best shifter to use?
Old Mar 1, 2011 | 08:08 PM
Franklin2's Avatar
Franklin2
If you have the money, I would use a Lokar. The handle would be long enough. I have used the "racing" type shifters, and besides having to build a console to raise it high enough, I hated the slap style gated shifter. It was so aggravating going from reverse to drive and then back with all that interlock junk.
Old Mar 1, 2011 | 08:10 PM
Archion's Avatar
Archion
Veteran: Marine Corps
B&M makes a truck shiftter that has a taller handle as well
Old Mar 1, 2011 | 08:11 PM
1981 F_100's Avatar
1981 F_100
yeah, i was looking into it. i have an 81' f100 what lokar would i get cause i see that theres different types
Old Mar 1, 2011 | 08:33 PM
80FlareSide's Avatar
80FlareSide
This is something I have recently discovered and put on my list of "want to do's" as well. Lokar makes a few different models, as does Gennie. Key difference is that Lokar is a push-button type, and Gennie is gated.
Old Mar 1, 2011 | 08:42 PM
1981 F_100's Avatar
1981 F_100
and wht type are you thinking bout getting, is the transmission cable?
Old Mar 2, 2011 | 06:15 AM
80FlareSide
Most of the Lokars and Gennies mount right to the the tranny. I havent worked out all the logistics yet, but I am hoping that I will just be able to cut a hole in the trans-cover in a place similar to where the shifter would go on a manual. That way there is a direct linkage connection to the shifter on tranny. There are still issues i need to think through though.
1) Can I actually mount it where I would like to?
2) How tall should I get? I really like the look of the double bends, but think they may be too tall.
3) B/U lights and Neutral Safety switch. How do I get those to work?
4) Gear indicator. Can I rig the one in the dash to work, or do I need to figure something else out?
Unfortunately, I think I may have to just go buy it, try to install, then work through complications 1-4 as I go along. Alot of potential to be a $300 boondoggle.
Old Mar 2, 2011 | 07:00 AM
first today's Avatar
first today
Cheap auto floor shifter route. Get one from an aerostar. It is cable driven and has the shift indicator. It is a perfect height in the truck. About twenty bucks in the junkyard.
jmc63
Mar 2, 2023 02:30 PM
reamer
Feb 19, 2017 09:43 PM
GMbusa
Dec 14, 2015 11:42 AM
V10-XXL
Nov 23, 2015 03:37 PM
anthony f47
Nov 18, 2015 01:18 PM
