Sponsored by: Real Truck
Maglite Mounting
Old Mar 4, 2006 | 11:39 AM
  #61
stebab's Avatar
stebab
I am installing this right now (between beers and ESPN) in the same place that Bear Hunter has his. Should I use switched power or constant power?
Old Mar 4, 2006 | 11:51 AM
  #62
kb5sej's Avatar
kb5sej
Mine is on constant power.
Old Mar 4, 2006 | 11:57 AM
  #63
bneafus's Avatar
bneafus
Originally Posted by wlihntr
well then i guess i will put it this way ( and i am sure in your opinion you will think me a fool) i am not going change where the flashlight is mounted because i "might" be in a rollover accident and in that accident i "might" hit my head on the light, i am not that big of a fatalist.
ps. if i wanted you opinion on my attitude...i would have asked for it
Well Brother....I've only been a paramedic/firefighter in a busy metro fire department for 26 years....No where near the experience of the journalist I'm sure!! But I've seen many people killed from lack of seat belts(kudos to you!) and none I can remember from a few small itmes in the cab. If someone's that concerned about it,they'd have to get rid of every loose item in there!
BTW,I keep my rechargeable mounted on the ceiling too....Good access if I rollover and can't get out...Maybe could signal with it!
Keep driving safe with your belt on...You'll be fine!!
Also....What's the bracket or item behind the flashlight??
Old Mar 4, 2006 | 12:10 PM
  #64
stebab's Avatar
stebab
Great... I have found a power source for that... Just didn't want to be running the battery down... That said, I have the HD Alternator just in case! LOL
Old Mar 4, 2006 | 02:05 PM
  #65
wlihntr's Avatar
wlihntr
check my gallery, its for an LCD tv
so you are in littleton? i used to be a manager at the Soundtrack on bowles and wadsworth
Old Mar 4, 2006 | 02:07 PM
  #66
bneafus's Avatar
bneafus
Very cool,guess I need one!
Old Mar 5, 2006 | 07:48 AM
  #67
cangim's Avatar
cangim
I have run mine on constant power in the 7 years I have had it. No vehicle battery issues and now issues with overcharging. barely replaced the battery in it about 3 months ago. These things are sweet, bright light, any and evertime you need it.
Old Mar 5, 2006 | 09:12 AM
  #68
kb5sej's Avatar
kb5sej
Thumbs up
As far as running the battery down... I have never had any problems with it however for long trips via air where the truck sits in the parking lot i usually turn off the amateur radio and lay, flashlight in the seat, and disconnect anything in the aux power... just in case!
Kevin
Old Mar 5, 2006 | 09:16 AM
  #69
bneafus's Avatar
bneafus
Yah,born and raised,been in and out over the years...
therigwelder
Jan 9, 2016 09:10 AM
Jonnylightning
May 1, 2015 06:38 AM
jtlinn1975
15
Nov 20, 2014 10:22 PM
chaser1602
Feb 25, 2014 03:29 PM
oldmansimek
Dec 25, 2006 11:50 AM
