Sponsored by: Real Truck
Maglite Mounting
Old Jan 22, 2006 | 08:08 AM
  #31
stebab's Avatar
stebab
Originally Posted by cangim
Mine is mounted pretty much the exact same as Bear Hunters is. If I were to do it again. I'd just move it back as far as possible as to still get it out of the holder easy. I tend to kick mine alot. But it is always there when I need it and always charged.
Always in there and always charged...
Have you guys gotthem set up to charge while in your truck?? That would be a cool idea.
Old Jan 22, 2006 | 06:23 PM
  #32
cangim's Avatar
cangim
My brother gave it to me for Christmas about 8 years ago, it is a rechargable MagLite and takes a 12V halogen lamp. Think back then it was around 80 bucks. I have only had to replace the battery once in the 8 years and the lamp 2 times. But other than that it is great.
Old Jan 22, 2006 | 06:25 PM
  #33
stebab's Avatar
stebab
And you mount the mounting brackets and the charget in your truck? Have you got a close up picture of that?
Old Jan 22, 2006 | 06:26 PM
  #34
stebab's Avatar
stebab
Originally Posted by jwith68
I mounted mine (4D) beside the seat like many others. However, I did not want to drill through the carpet and into the floor metal. I made a 14ga sheetmetal mount that bolts to the seat frame and extends mounting pads for the Maglite clips down at the same slope as the floor, about 3/8" up off the carpet. I just used machine screws with nuts and lock washers on the back side to attach the clips to my mount. The mount is held to the seat frame by two 1/4"-28 x 3/4" bolts. There is an area of the frame that is clear of moving parts and plenty thick enough to thread to 1/4"-28. Everything's painted black (black oxide bolt heads.) Looks professional, works great, and no holes in the carpet.
Can you post a picture of that?
Old Jan 22, 2006 | 07:24 PM
  #35
cangim's Avatar
cangim
Yes it charges from the Truck, i am going to install a new gauge face tomorrow and will take some pictures then.
Old Jan 22, 2006 | 08:24 PM
  #36
dsldandually's Avatar
dsldandually
I've got the rechargable mounted in the tray behind the front seat (reg. cab) easily reachable and out of sight I do like the 7d though you can put a knot on someones head so big they will need a step ladder to rub it :- )
Old Jan 22, 2006 | 09:01 PM
  #37
kb5sej's Avatar
kb5sej
I have a streamlight rechargeable mounted to the seatbelt box with commerical velcro. It doesnt move and the wiring is ran inside the door jam.
I also have a lithium SureFire G2 velcroed inside the overhead console. It is extremely handy and bright. The <5" doesnt make a good club like the 6-cell maglites mentioned above (which are available daily on eBay BTW)
I shouldnt tell this... but when i "attempted" to mount my streamlight charger to the carpeted area between the seat and the door (without looking first). I joyously ran a self tapping screw right throught the middle of the main seat wiring harness. That was a lovely repair job. )
Old Jan 23, 2006 | 02:35 AM
  #38
cangim's Avatar
cangim
Here is a link to the pic, haven't done the gauges yet, will post some of those in my gallery when done.
https://www.ford-trucks.com/user_gal...id=103394&.jpg
Old Jan 25, 2006 | 08:04 PM
  #39
stebab's Avatar
stebab
The newer lights appear to have a different charger. Does anyone have one of the newer lights mounted in their truck with the new charger? Does it actually mount.
See this:
http://cgi.ebay.com/MagLite-RX1019-R...QQcmdZViewItem
Old Jan 25, 2006 | 08:06 PM
  #40
stebab's Avatar
stebab
Or on second look... is that the same charger? Hmmm...
Old Jan 25, 2006 | 09:38 PM
  #41
cangim's Avatar
cangim
See this:
Looks like it is the exact same as mine, I hard wired the charger rather than using the supplied cigarette adapter.
Old Jan 26, 2006 | 06:29 AM
  #42
stebab's Avatar
stebab
Does the charging bracket actual mount the light or did you have to use those two brackets also?
Old Jan 26, 2006 | 05:03 PM
  #43
cangim's Avatar
cangim
There are two pieces to the bracket. Two metal brackets, so you can mount the light in two places if you want I guess. Mount the metal on in the truck, the big plastic housing snaps into the metal base. Then the light snaps into the Housing (charging bracket). I still have the second base that I haven't used for anything.
Old Jan 27, 2006 | 07:07 AM
  #44
CmprSpecial's Avatar
CmprSpecial
I wish I had the cash for the rechargable version
Old Jan 27, 2006 | 07:09 AM
  #45
stebab's Avatar
stebab
That's what i needed to know... i'm going to order one today.
