Sponsored by: Real Truck
Maglite Mounting
Old Jan 28, 2006 | 01:58 PM
  #46
stebab's Avatar
stebab
Where is the best place to get the power source for the rechargeable maglite from? I just bought the light. I found several on eBay and they were are reasonably priced.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
My question in this... you don't want this light charging all the time, I wouldn't think. Seems like if it were only charging while the truck was running, that would be plenty... OR attach it to an upfitter swich, maybe, and charge it when you feel like charging it?
Are the upfitter switches ignition dependent? Meaning, are the switches switched?
Old Jan 28, 2006 | 04:28 PM
  #47
cangim's Avatar
cangim
I have mine connected all the time, truck on or not, the directions that came with mine said it controlled the charging. I haven't had any problems with it connected this way. Have replaced the battery once in the 8 years that I have owned it.
Old Jan 28, 2006 | 04:35 PM
  #48
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Wow... and I just put my maglight in the driver's door panal in my Excursion. Are the trucks the same?
Doesn't rattle, alkaline batteries last a long time, can't come loose... and still is easy to grab and take a swing at someone if needed!!!!
Now, if needing or wanting a rechargable light... then I underdtand the need to mount in a place where power can be pig-tailed into.
Old Jan 28, 2006 | 09:40 PM
  #49
Customz's Avatar
Customz
I just tuck mine in between the driver seat and counsel along with my club. Can someone post a pick of the 7d maglight. I haven't seen one.
I haven't had a problem with my non-rechareable maglite losing power. They are great products, but sounds like I need a 7d. haha
Old Jan 29, 2006 | 01:03 AM
  #50
Bear Hunter's Avatar
Bear Hunter
I believe one of those could double as a pinchweld cover
Old Jan 29, 2006 | 06:52 AM
  #51
Lnd Svyr's Avatar
Lnd Svyr
The last thing one needs to worry about in a roll over in a Super Duty (or any vehicle, for that matter) is loose cargo. I know I read somewhere about how bad they (SD) do in roll overs (which is why I had considered a rollbar--don't know how that would work in a crewcab though). Still love the SD, though.
Keep my Maglite in the console. But, after reading these posts, think I will keep it in the door. I like Bearhunter's mount--but I haven't seen any mounts made for the regular Mags, yet.
Old Jan 29, 2006 | 02:16 PM
  #52
colt74's Avatar
colt74
4wd Low
I got a maglite for christmas and it came with mounting brackets.
Old Jan 29, 2006 | 02:24 PM
  #53
timcommon's Avatar
timcommon
Got one as a present and is also had mounting brackets!
Old Jan 29, 2006 | 02:53 PM
  #54
kevcbm's Avatar
kevcbm
I paid $5 for mount at the local Army/navy store.
Old Jan 29, 2006 | 04:07 PM
  #55
whooey's Avatar
whooey
Stock Mags are weak, you need to soup em up a bit. A stock Maglite (2D) puts out maybe 30 Lumens. I have a 3D modded to run off of 9 AA batteries, that uses a welych allen 1185 bulb that puts out 1234 bulb lumens!! I had to put in a metal reflector and a new socket to hold the bulb, the stock parts would melt almost instanlty with this set up.
See www.candlepowerforums.com for more....
BTW, my mag is flamed....
http://img479.imageshack.us/img479/8...arty0072pu.jpg
Image changed to link. -Beast12
Old Jan 29, 2006 | 04:30 PM
  #56
stebab's Avatar
stebab
I went to that site and it's WAY over my head. Is the a "Souped Up Mag Lights for Dummys" version somewhere?
Did you do that flame paint yourself?
Old Jan 29, 2006 | 04:34 PM
  #57
kevcbm's Avatar
kevcbm
Too fancy, I'd be afraid to use it for self defense. If I host some kind of a grand opening and need a spot light, maybe.
Old Jan 29, 2006 | 04:43 PM
  #58
Beast12's Avatar
Beast12
Does anyone know of a good spot to mount one in my Focus?
-Matt
Old Jan 29, 2006 | 06:08 PM
  #59
cangim's Avatar
cangim
How about center of the hood up a little high, this way maybe oncoming traffic will think you are a locomotive....
Old Feb 3, 2006 | 07:13 AM
  #60
stebab's Avatar
stebab
I got my Maglite rechargeable (RX1019) in the mail last night (got it off of eBay) and I am very happy with it. The mount for it is unbelievably strong and tight. It will be perfect.
