Glow Plug 101
Old Dec 15, 2005 | 05:29 PM
roaky81's Avatar
roaky81
Glow Plug 101
Does anyone have the test procedures to check out the Engine Oil Temperature sensor? After reading on the system, if this sensor is stuck on a reading above 55' C, then the PCM won't provide a ground to the GPR. And yes, I'm going to beat this mule till we cross the finish line! Oh... and Happy Holidays and here's wish'n you receive some PSD gifts under the tree.
Old Dec 15, 2005 | 05:53 PM
SpringerPop's Avatar
SpringerPop
Good thinking, Roaky! Could be.
Sorry I don't know the answer to the question on checkout procedures, but your logic is good.
Pop
Old Dec 15, 2005 | 07:35 PM
clux's Avatar
clux
Wouldn't it be easier just to test to see if the PCM is providing ground for the GPR first?
Old Dec 15, 2005 | 09:31 PM
cangim's Avatar
cangim
I don't know if this helps or not, but it will give you the location to the plug and a brief description. http://www .nav-international.com.br/frame_master.asp?tipo=powerStroke&pg=manual_i/powerStroke/hs.asp
Old Dec 16, 2005 | 01:19 PM
roaky81's Avatar
roaky81
I'm not getting a ground from the PCM at the gpr. I have yet to get under the dash and check the pin out on the pcm. I'll post another topic if I find out anything.
cf21684
May 11, 2013 12:23 PM
rangerbob406
Jan 19, 2013 08:14 PM
savage250
Feb 1, 2012 10:43 AM
flyboy5111
Electrical Systems/Wiring
Jan 22, 2009 12:35 PM
bloomy63
Dec 7, 2006 07:07 PM
