Outside air temp. wrong.
Old Jan 22, 2009 | 12:25 PM
flyboy5111's Avatar
flyboy5111
On a 08 Exp. the temp. reads 10 too low. I removed the ambient sensor from in front of radiator, cleaned connection, checked ohms of sensor, the resistance went lower as I warmed it. The temp. read 75 with sensor removed. reinstalled sensor, still read low. Borrowed sensor from wifes 05 Montego. Still reading low. Is there another sensor somewhere? Thanks.
Old Jan 22, 2009 | 12:35 PM
HomerWinzlow's Avatar
HomerWinzlow
The temp reading is always approximate. You wont get changes until you are rolling 35mph continous. The last reading read will often be the first reading when you start next time and it will normalize as you drive. If you have a problem and are under warranty let the dealer try to fix it first.
John Hill
Testing.....
Dec 18, 2016 08:53 AM
2001NaviA4WD
Jun 28, 2016 07:56 AM
mwilliams0326
Nov 16, 2015 09:02 AM
2civicrr
6.7L Power Stroke Diesel
Nov 7, 2015 12:04 PM
cajohnson
13
Jun 11, 2015 09:14 PM
