icp sensor
Old Apr 13, 2009 | 11:07 AM
rangerbob406's Avatar
rangerbob406
icp sensor
i've been picking up a code 2285 recently and i've read that it is the icp sensor does the code mean that the sensor is bad or that it is reading the wrong pressure and what size sensor socket do i need to replace the sensor
Old Jan 19, 2013 | 06:35 PM
Jackofall's Avatar
Jackofall
You most likely have a bad sensor. You need a 1 1/16" deep socket, and it should be a 3/8" drive with a universal and several extensions if you replace it from above. I just changed mine and it took 3 hours, but it isn't hard, just time consuming. Snap-on makes a socket for the ICP, it's $38 +/- and I thought it was worth it.
Old Jan 19, 2013 | 07:06 PM
mustang_309's Avatar
mustang_309
What year is your truck? Your ICP may be on the passenger side valve cover
Old Jan 19, 2013 | 07:40 PM
dannyboy950's Avatar
dannyboy950
Late 04 and up the sensor is on the passenger valve cover towards the front.
By the way there is an o-ring between the valve cover and the oil rail do not dislodge it when removeing sensor or screwing in new one. Also has o-ring on sensor itself.
Old Jan 19, 2013 | 08:14 PM
BLADE35's Avatar
BLADE35
P2285 ICP Injector Control Pressure Sensor Circuit Low Causes are Open circuit, short to ground, ICP sensor
To be shure its the ICP sensor I would check ICPV @ KOEO should be .18-.24volts at KOEO
And Most time it is Bad ICP sensor itself
But it is Electrical DTC so it could be a couple other things
you will also need to inspect ICP Wire Pigtail for Oil
Tugly
13
Dec 20, 2013 04:41 AM
lakewood
Apr 25, 2013 09:59 AM
natem8301
Mar 15, 2011 03:17 PM
7174SC
Jun 11, 2010 07:21 PM
jnye6625
20
Mar 7, 2007 02:51 PM
