Physics
Old Dec 8, 2005 | 06:48 PM
  #31
Nohaj1's Avatar
Nohaj1
If you move a toy car with your hand along a tread mill it still moves because the motion is not based on the wheels. Same thing with the plane the engines move it not the wheels.
Old Dec 8, 2005 | 06:50 PM
  #32
Nitramjr's Avatar
Nitramjr
Originally Posted by sigma
A plane (747 passenger jet) is sitting on a runway that can move (some sort of band conveyor). The plane moves in one direction, while the conveyor moves in the opposite direction. This conveyor has a control system that tracks the planes speed and tunes the speed of the conveyor to be exactly the same (but in the opposite direction).
Will the plane (747 passenger jet) take off or not?
Unless the plane is tied off to something, it will accelerate forward, regardless of how fast the conveyor is moving. The forward speed of the plane is a function of thrust versus drag and in this case, the freely spinning wheels will create no drag and will thus be unable to prevent the plane from accelerating. Once the plane reaches the correct airspeed (where lift exceeds weight), it will in fact be flying.
Old Dec 8, 2005 | 06:51 PM
  #33
78f-150Supercab's Avatar
78f-150Supercab
edited post, will further explain later
Old Dec 8, 2005 | 06:54 PM
  #34
jgc2521's Avatar
jgc2521
wouldnt overall speed be 0mph then.. compared to the ground
Old Dec 8, 2005 | 07:04 PM
  #35
Nitramjr's Avatar
Nitramjr
The conveyor would only have an impact on the movement of the plane if the wheels were not free to rotate. Since wheel speed is not a factor in whether the plane moves (thrust versus drag) the plane would move forward and ultimately fly.
Old Dec 8, 2005 | 07:15 PM
  #36
jake00's Avatar
jake00
Originally Posted by DonsFx4
Sigma...congrats on posting a great topic! Got a lot of people thinking here.
Too bad it didn't include a poll to show how many think it will or will not fly!
Which, by the way, it WILL!!!
could you elaborate?
Old Dec 8, 2005 | 07:19 PM
  #37
78f-150Supercab
edited again, oye, this is complicated. will reply again later :-P
Old Dec 8, 2005 | 07:25 PM
  #38
DonsFx4's Avatar
DonsFx4
Nitramjr...you got it right. 78f-150Super, sometimes I just can't come up with the right words to get my point across, so bear with me here:
The physical forces involved:
Thrust of engines - the high velocity jet blast out the engines will have a reactionary force, which is to move the plane forward
Forward velocity - as forward velocity increases, so does the speed of the air moving over the wings. The faster the speed, the more lift produced
Airplane wheels - The wheels are free-spinning, except of course when brakes are applied. As long as they are spinning, they act like roller bearings and completely nullify the effect of the runway
Runway - moving or stationary, it makes no difference to the plane as long as the engines are producing thrust, the plane is propelled forward by the reaction to that thrust, and the forward velocity relative to the AIR (not the runway) is enough to creat lift.
Whew...now it's time for a shot and a beer!
Old Dec 8, 2005 | 07:27 PM
  #39
78f-150Supercab
I was taking into account too many factors. I am leaning towards your answer right now DonsFx4. Still need to ponder.
EDIT: Yeah, Dons, you're probably right. I was going overboard with friction when the wheels could simply be free moving :-P In that case, there is negligible force between the plane and the ground and the engines can push the plane forward using the air as the medium.<o></o>
Old Dec 8, 2005 | 07:33 PM
  #40
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
DonsFx4 and the rest that said the plane will fly are correct.
Old Dec 8, 2005 | 07:34 PM
  #41
maa139's Avatar
maa139
Don't forget about this statement in the original problem. This statement means that the speed of the plane relative to the ground is 0.
Old Dec 8, 2005 | 07:40 PM
  #42
78f-150Supercab
But that only applies if the force of the plane is solely on the ground (the belt). But as Dons noted, the wheels act like bearings, negating any force that the belt has on the plane and it is the thrust that moves the plane forward.
  #43
Nitramjr's Avatar
Nitramjr
No, the speed of the conveyor will only match the speed of the rotating wheels, in the opposite direction.
Old Dec 8, 2005 | 07:44 PM
  #44
maa139's Avatar
maa139
Ooooohhhhhhhhh....That's why I'm a programmer and not an engineer.
Old Dec 8, 2005 | 07:45 PM
  #45
78f-150Supercab
That is wrong. The speed of the belt matches the speed of the plane, not just the speed of the rotating wheels.
