Physics
Old Dec 16, 2005 | 06:11 AM
  #181
Nitramjr's Avatar
Nitramjr
Originally Posted by BrianA
If your treadmill allows the plane to achieve forward velocity and matches AIRSPEED with a counter acting GROUNDSPEED as seen on the treadmill, then yes the plane will fly, because it is free to achieve whatever airspeed it wants, the wheels are simply spinning faster than they would on a fixed runway.
If the conveyor is such that is offsets the airplane's GROUNDSPEED with an equal and oppostie GROUNDSPEED, the plan would sit motionless and never take off.
So if the plane tried to move forward (relative to the ground) at 10 mph, the conveyor belt would automatically adjust and run 10 mph in the opposite direction so that the plane never moved.
groundspeed / airspeed : THAT DISTINCTION is the key to understanding it all.
Actually, that is exactly the trap to this question. The conveyor would not care one bit about airspeed or groundspeed. Once the wheels start rotating and the conveyor started moving, their speed (of the wheels and conveyor)would only be relative to each other and have nothing to do with the airspeed or the groundspeed of the plane. Either way of looking at it, the planes engines thrust against air and the plane moves forward. There is nothing holding it back.
Airspeed is strictly a measure of air past the wing. A plane that is parked into a 50 knot headwind has an airspeed of 50 knots (yes it does ) and a groundspeed of 0. A plane flying at 50 knot airspeed into a 50 knot headwind has an airspeed of 50 knot but a groundspeed of 0. Turn it around 180° and the plane with the same 50 knot airspeed now has a ground speed of 100 knots.
Some small planes (Cessna 152, Piper Cubs) can be flown slow enough that in a strong headwind they will fly backward, relative to the ground. As far as the plane knows, it still has enough relative wind to maintain lift and thus fly.
That is why takeoffs and landings are always made on the runway that is most into the wind. It makes your takeoff and landing distance much shorter. Aircraft carriers turn into the wind and adjust their thru the water speed to make a 30 knot or so headwind. Makes it much easier on the catapults when launching and greatly slows the relative speed on landing.
Oh well, I have a plane to catch. I wonder if Logan Airport (KBOS) has a conveyor we can borrow this morning.
Merry Christmas all.....
Ray
Old Dec 16, 2005 | 06:37 AM
  #182
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by andym
I just can't believe an FTE moderator would pull that kind of stunt.
Seems to me, he was, and is speaking his point, something you or any member can.... and often do.
Just because he is a moderator does not mean....he does not have an opinion, nor is allowed to speak it.
Old Dec 16, 2005 | 07:45 AM
  #183
alchymist's Avatar
alchymist
"Mifflin Clay"
Ray
"the planes engines thrust against air" Not quite, ...... the thrust is an .."equal and opposite reaction..." thing. The thrust against the engine (and thus the air frame) is the reaction to the air/fuel mixture being expelled from the engine. It does not push or thrust against the air. This "the planes engines thrust against air " has been mentioned in a number of the above posts ....Just a minor point ......
Old Dec 16, 2005 | 08:08 AM
  #184
dkstuck's Avatar
dkstuck
and alittle something to help this go more pages,,,,he he he
Old Dec 16, 2005 | 09:44 AM
  #185
alchymist's Avatar
alchymist
"Mifflin Clay"
Well, it's true........but, you found me out ......
Old Dec 16, 2005 | 10:20 AM
  #186
andym's Avatar
andym
Of course - I didn't mean to imply that couldn't/wasn't. I meant the statement literally. Meaning, I think he disagrees with us, and we aren't being played after all.
Old Dec 24, 2005 | 02:09 PM
  #187
Bill_Beyer's Avatar
Bill_Beyer
{Taking off Mod hat}
Good lord! 13 pages of this stuff, amazing! Bottom line as long as the conveyer is long enough for the plane to get up enough airspeed of course it will fly. Best analogy I can think of, take a conventional dragster and put it 1/4 mile track made of ice. It'll never move because the power is being applied to the wheels and they can't overcome the lack of friction it takes for forward momentum. Now take a jet dragster and put it on the same track. It'll shoot off like a...well...a jet. Why? Because it's not using friction to move forward it's using thrust, the wheels don't have to spin at all.
{Putting Mod hat back on}
Merry Xmas everyone!
AirLiftCompany
Vendor Specials, Discounts, Product Announcements & Group Buys
Jan 5, 2013 01:12 PM
cjben
May 3, 2010 11:31 PM
jake00
129
Dec 20, 2007 09:36 AM
herman391
24
Jan 3, 2007 10:44 PM
