rewired headlights
Old Nov 30, 2005 | 02:41 PM
22mill's Avatar
22mill
Thumbs up rewired headlights
I just rewired my headlights on my 96' F150, i installed 2, 30 amp relays for the high and low beam. after reading the article in the tech section it made me courious to how good it would be. and let me tell ya its a big difference in how bright they are!!! i would recommend anyone doing this to get brighter lights. now i am going to install higher wattage lights to get even better view. just wanted to say that it is a great improvement.
Old Nov 30, 2005 | 03:39 PM
Mike8500's Avatar
Mike8500
4wd Low
Where did you locate the relays. Did you just splice it in and use the stock wiring or did you remove the stock wires and run heavier gauge wire??
Old Dec 1, 2005 | 04:27 AM
22mill's Avatar
22mill
well i located the relays on the pass side fender just by the jack, i have another relay there for lights that i mounted on the front bumper, well i pulled the light socket and cut the wires about a inch from it, then spliced in 14 ga. wire, which runs to the relays, i have 12 ga. feeding the relays from the starter solenoid. and i used the wires that org fed the headlights to use as the relay wire. it took about a hour to do. and i sure do like how they work now. i had a buddy do the same on his 86' stang and he liked how is turned out as well, if ya have anymore questions just holler.
80f250ranger
Apr 22, 2013 06:08 PM
finneys98xj
45
Aug 3, 2012 11:50 PM
damac
22
Feb 16, 2010 08:49 AM
Primered 1966 f100
Jan 23, 2008 01:25 PM
Nuthin
Sep 28, 2006 10:51 AM
