Headlight rewiring/upgrade
Old Feb 4, 2011 | 10:43 PM
finneys98xj's Avatar
finneys98xj
I have read lots of old post how a few have rewired there headlights to run though relays to take the stress off the switch does anyone have a diagram/parts list of this mod?
I figured it would be a great idea to do since we are going to be stripping the truck down here shortly to redo the drivetrain.
And also is the headlights wired the same for the 67-72 model years as the 73-79 years? I want to take the stress off the light switch on all my trucks. The 78/72/72/and 63.
Old Feb 4, 2011 | 11:09 PM
WarOzz's Avatar
WarOzz
It's a pretty easy mod, done it to just about every ford truck I have owned. Here is good "how to" Whiter Whites, Brighter Brights .: Articles
Old Feb 4, 2011 | 11:12 PM
finneys98xj
What years will this mod work for?
Old Feb 4, 2011 | 11:24 PM
WarOzz's Avatar
WarOzz
I am not sure what year Ford finally fixed this but it was in the late 90's I think. I can say for sure ANY pre 1994 truck would benefit from this upgrade.
Old Feb 5, 2011 | 12:04 AM
The Confederate's Avatar
The Confederate
I just made that especially for you!! That's how to hook it up, plain and simple!! Pretty much any vehicle can be done much the same way. Hope it helps! And anyone can use this pic as needed.
Old Feb 5, 2011 | 10:30 AM
WarOzz's Avatar
WarOzz
Nice diagram
Old Feb 5, 2011 | 02:02 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
To be honest, the LMC wiring harness is super easy and very reasonable and is a very nice kit to get the job done.
Buying everything seperate is going to be way more than the $29.99 at LMC.
Josh
Old Feb 5, 2011 | 04:56 PM
F-250 restorer's Avatar
F-250 restorer
I was druelling over a slick 67 bumpside, and noticed he had a small 5"x4" digital box by each headlight, with halogen lights. I was just curious if anyone knew what it was.
Old Feb 5, 2011 | 04:59 PM
finneys98xj
I have seen them. Try Ebay.
Old Feb 5, 2011 | 05:10 PM
Bullitt390's Avatar
Bullitt390
Were they halogens or were they running HID with ballasts?
You can get HID kits (bulbs and ballast) for $50 anymore, but then it takes some fab work to install some projectors.
Josh
Old Feb 5, 2011 | 05:46 PM
wasa 1500's Avatar
wasa 1500
I am running lmc head lamps,AND I LIKE UM !
Had to cut about 1/4" out of the back of my h.l. buckets, for the rubber boot on the rear of h.l. housing, now can replace bulb only. even with the stock bulb what a differance.
I did the relay/wiring before, and it did help, but I say - UP GRADE!!!!!
Old Feb 5, 2011 | 06:52 PM
F-250 restorer
Nice truck! I'm curious about the wiper mod you did. Mine seem to be 'lazy'. One flap they go down to the weatherstripping on the windsheild, and the next they stop 6" above! I know that fixing that is not part of installing an intermintent system, but if you have any tips I'd appreciate it.
Does anyone have any photos of where they mounted the relays for the headlight mod?
Old Feb 5, 2011 | 06:57 PM
finneys98xj
If anyone has a lmc harness and want to sell it PM ME.
Old Feb 5, 2011 | 07:04 PM
F-250 restorer
They only run like $30.
Old Feb 5, 2011 | 07:14 PM
bucks77ford's Avatar
bucks77ford
Josh
Very easy to hook up. The only complaint I have is the relays used in LMCs harness are el cheapos. Every once in awhile my headlights don't come on the first time. I'm eventually going to upgrade them.
