switch out
Old Nov 30, 2005 | 04:45 AM
ThaRain_GA's Avatar
ThaRain_GA
switch out
how could i switch a automatic trans in an 91 4x4 ranger for a manual. also are body lifts worth the money, safety and durabilty wise. thanks.
Old Nov 30, 2005 | 05:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 30, 2005 | 07:09 AM
The SnoMan's Avatar
The SnoMan
Tranny type swaps are always the easiest with a donor truck but it is doable. With body lift you must remeber the the body goes up the the engine and fan stay put and if you lift it much, you may have issue with cooling because you have to remove shroud and also steering column and connection to steering box can be a issue with bigger body lifts. If you want to do it keep it at 2 inch or less for least amount of problems if you are new to this stuff.
Old Dec 4, 2005 | 02:13 AM
ThaRain_GA's Avatar
ThaRain_GA
hey that sounds good, i never though about the engine and cooling deal with body lift. thanks
mattt181
19
Jun 12, 2023 12:06 PM
Stebs
1997 - 2003 F150
Mar 3, 2013 07:30 AM
1BadHabit
Feb 26, 2012 01:25 PM
23larry24
Dec 30, 2008 04:42 PM
94yj
Nov 16, 2008 12:52 PM
