Sponsored by: Real Truck
ESOF Switch Bezel
Old Feb 26, 2012 | 12:32 PM
1BadHabit's Avatar
1BadHabit
ESOF Switch Bezel
The ESOF bezel on the 05+ dash is a separate piece from the main dash. Does anyone have part numbers for the various iterations of it? Or a link to parts diagrams for the dash?
ie: 4x4 switch only, 4x4 switch plus backup sensor switch, 4x4 switch plus backup sensor switch plus power rear window switch.
Old Feb 26, 2012 | 12:55 PM
rs4-380's Avatar
rs4-380
probably not what you are after, but this is the blank plate (manual shift)
P/N: 5C3Z-25047A04A-AA
Old Feb 26, 2012 | 01:25 PM
1BadHabit's Avatar
1BadHabit
No not exactly what I was after, but you sure got me started down the right path.
A little Google Fu and I was able to find them all!
However, these are assemblies that come with the switch(es). I wonder if just the plastic bezel is available?
For future reference for others:
Bezel **3Z-25047A04-AAA Black, LH, From: 07/19/2004 2005/; Man Transfer Case And Man Hubs, Less Power Sliding Rear Window, Less Reverse Proximity Sensor
Bezel **3Z-25047A04-BAA Black, Includes Switch, LH, From: 07/19/2004 2005/; Man Transfer Case And Man Hubs, Less Power Sliding Rear Window, With Reverse Proximity Sensor
Bezel **3Z-25047A04-CAA Black, Includes Switches, LH, From: 07/19/2004 2005/; Electric Trans Case And Auto Hubs, Less Power Sliding Rear Window, Less Reverse Proximity Sensor
Bezel **3Z-25047A04-DAA Black, Includes Switches, LH, From: 07/19/2004 2005/; Electric Trans Case And Auto Hubs, Less Power Sliding Rear Window, With Reverse Proximity Sensor
Bezel **3Z-25047A04-EAA Black, LH, From: 07/19/2004 2005/; Man Transfer Case And Man Hubs, With Power Sliding Rear Window, Less Reverse Proximity Sensor
Bezel **3Z-25047A04-FAA Black, Includes Switch, LH, From: 07/19/2004 2005/; Less Transfer Case, With Power Sliding Rear Window, With Reverse Proximity Sensor
Bezel **3Z-25047A04-GAA Black, Includes Switch, LH, From: 07/19/2004 2005/; Electric Trans Case And Auto Hubs, With Power Sliding Rear Window, Less Reverse Proximity Sensor
Bezel **3Z-25047A04-HAA Black, Includes Switches, LH, From: 07/19/2004 2005/; Electric Trans Case And Auto Hubs, With Power Sliding Rear Window, With Reverse Proximity Sensor
Bezel **3Z-25047A04-AAA Black, LH, From: 07/19/2004 2005/; Less Transfer Case, Less Power Sliding Rear Window, Less Reverse Proximity Sensor
Bezel **3Z-25047A04-BAA Black, Includes Switch, LH, From: 07/19/2004 2005/; Less Transfer Case, Less Power Sliding Rear Window, With Reverse Proximity Sensor
Bezel **3Z-25047A04-EAA Black, LH, From: 07/19/2004 2005/; Less Transfer Case, With Power Sliding Rear Window, Less Reverse Proximity Sensor
Bezel **3Z-25047A04-FAA Black, Includes Switch, LH, From: 07/19/2004 2005/; Man Transfer Case And Man Hubs, With Power Sliding Rear Window, With Reverse Proximity Sensor
2SONS
Apr 30, 2013 10:26 AM
rotti799
2009 - 2014 F150
Feb 28, 2011 02:48 AM
kabman
2004 - 2008 F150
Oct 6, 2008 09:13 PM
05lariatPSD
Mar 20, 2008 09:49 AM
