Sponsored by: Auxito
4x4 switch
Old Feb 28, 2013 | 07:24 PM
Stebs's Avatar
Stebs
4x4 switch
I am needing to replace the selector switch for my 4x4 on my 2003 F150 Lariat FX4... I already have the new switch. Whats the best way to get in there to remove and replace the switch?
Old Mar 1, 2013 | 01:05 PM
Bluegrass 7's Avatar
Bluegrass 7
Before you do this, how did you determine the switch is faulty if it was not tested to begin with?
I suspect some guessing is going on for a 4x4 issue.
What is the real problem?
The system is operationally quite complex so you need to give some info or learn how it works before diving in by changing parts.
Good luck.
Old Mar 1, 2013 | 04:52 PM
Stebs's Avatar
Stebs
The **** no longer "clicks" into place and it just spins... Its the switch and not the **** because I have pulled the **** and the shaft on the switch just spins...
Old Mar 2, 2013 | 12:49 AM
Bluegrass 7
The Bezel around the air outlets, the radio and other controls prys off very carefully to expose access to all the control mountings.
Good luck.
Old Mar 2, 2013 | 07:03 AM
Spotty's Avatar
Spotty
Yep....pop that bezel off and IIRC the switch has 2 small screws that hold it onto the bezel. The wire connector is right there also...just un-plug that. Keep the old switch if you can. There is a small light bulb you can get out that is only specific for that switch. Otherwise if the illumination goes out in the future on the new switch, you have a bulb and socket rather than shelling out for another new switch. I fixed mine with a specialty type micro bulb......what a pain though.
Old Mar 2, 2013 | 12:42 PM
Stebs's Avatar
Stebs
Ah, Cool beans... Thanks Guys!
The light bulb in my current switch has already died, as well as the outer ****. For the past year I could put it in 4 wheel drive with the **** but had to pull the **** and turn the shaft by hand to get it back out of 4x4... I guess I know what todays project is gonna be...
Old Mar 3, 2013 | 12:31 AM
Stebs's Avatar
Stebs
Got it done, bezel just popped off... It took my longer to round up all the proper tools than it did swapping the switch out. Everything works good as new now.
Old Mar 3, 2013 | 07:30 AM
Spotty's Avatar
Spotty
...glad you got her..
DevotedDad
6.7L Power Stroke Diesel
18
Jul 3, 2012 11:46 AM
einsteindog
Jan 22, 2009 02:51 PM
PW01
1983 - 2012 Ranger & B-Series
Jul 7, 2006 07:04 AM
57_ford
Jan 15, 2003 08:07 PM
