Sponsored by: Real Truck
4wd switch lamp
Old Dec 22, 2008 | 01:11 PM
23larry24's Avatar
23larry24
4wd switch lamp
Does anyone know what the number of the bulb that is in the 4wd switch for illuminating the switch? Thanks.
Old Dec 22, 2008 | 02:19 PM
Downriver Thunder's Avatar
Downriver Thunder
It's not replaceable. I had mine go out and the dealer said you have to replace the switch assy.
Old Dec 22, 2008 | 09:35 PM
23larry24's Avatar
23larry24
Thanks for the info!
Old Dec 22, 2008 | 11:20 PM
aldridgec's Avatar
aldridgec
It's replaceable, but I don't know the number. I had to replace mine and a friend of mine had ordered two when he needed one for a job. Pretty sure it was just from the dealer. i had a tough time getting the green condom off that colors it. If I remember, I'll ask if it was from the dealer.
Old Dec 23, 2008 | 03:36 PM
Beerstalker's Avatar
Beerstalker
There is a thread in here about replacing it, do a search I just saw it last week.
Old Dec 23, 2008 | 03:46 PM
1975StroppeBaja's Avatar
1975StroppeBaja
A year ago two Ford dealers told me this was not a "serviceable" part and that I had to replace the switch assy at $45. I did some research and ended up with a decent solution.
see this page I put together:
2004 F250 Dash Light Bulbs
If your interested in fixing yours like I did, let me know, I can hook you up with some replacement bulbs.
Old Dec 23, 2008 | 05:48 PM
ReAX's Avatar
ReAX
They look like 178 or 164. I've seen bulbs that tiny before, but only from dealers.
Old Dec 29, 2008 | 07:52 PM
jhm3rd's Avatar
jhm3rd
In my 2002 F250 if you work the switch out of the panel you can use a simple flate blade screwdriver to remove the lamp in back ... it looks like a small LED .... I'd think the dealers would at least have the replacements
Old Dec 29, 2008 | 09:40 PM
1975StroppeBaja
Its actually a small bulb, not an LED. And according to two Ford dealers I contacted, they do not carry that particular bulb.
Its not a "servicable part", so they say. This was true as of Dec 2007 so maybe its worth asking again....
Old Dec 30, 2008 | 04:42 PM
23larry24's Avatar
23larry24
IJt's an odd bugger!
aircargoo
Mar 26, 2017 07:58 AM
Xamdrob
2009 - 2014 F150
Jan 20, 2017 12:35 PM
23larry24
13
Jan 16, 2017 12:08 PM
Dante827
Nov 14, 2016 08:26 AM
Aremee
Jul 26, 2016 09:57 AM
