351 or 460
Old Nov 25, 2005 | 08:11 PM
460bbl's Avatar
460bbl
351 or 460
want to put one or other in a tbird 86 coupe making street racer and a strip looking for engine and a c6 tranny can anyone help thanks doug...
Old Nov 28, 2005 | 04:38 AM
uuranium's Avatar
uuranium
are you gonna use a power adder, stroke the engine, aftermarket block.......?
Old Nov 28, 2005 | 10:43 PM
460bbl's Avatar
460bbl
Talking 351 or 460
just want to build a street and strip to play with hoping to be able to use 460 want the most hp i can get
Old Nov 29, 2005 | 02:40 AM
Matts72's Avatar
Matts72
In a car like that, a 351W built to a 393 will be faster than a 460 car, it will also be streetable. Putting a 460 in a car like that will be a total hack job...
Good luck and welcome to FTE!
Old Nov 29, 2005 | 09:52 AM
Kemicalburns's Avatar
Kemicalburns
guys put 460's into stangs all the time, but that was before the stroker market really took off. you can do anything you want and its your call on how it looks. if you cut corners it will look and handle like sh! t but if you do it right then it can look very clean and professional. i do think a 393 or 408 stroker would be a better build but if you want the cool factor of saying its a 460 by all means do it. check out stangnet.com and corral.net for more info
later
Old Nov 29, 2005 | 10:43 AM
derherr65's Avatar
derherr65
A 351, even with a stroker kit, is a lot lighter than a 460. Drag performance is about average power(in the rpm between shifts), weight and traction. Figure out the power levels you can afford with both engines. The power you need to know is the average power in the rpm range you'll be running. A c6 has 2.46, 1.46, 1 gearing. In my truck (optimally) that would mean 3000-5000 rpm. Then get the weights of both engines and your current motor. Add each engine weight to the weight of you car without it's engine. Divide each total weight by that correct engine's average power. The one with the better(higher) power/weight ratio will be faster.
Old Nov 29, 2005 | 12:22 PM
uuranium's Avatar
uuranium
if you do a 351 then gor for the stroker. www.coasthigh.com has the best stroker kits.
Old Nov 29, 2005 | 12:51 PM
garsten's Avatar
garsten
the 86 tbird is a fox body car, so there is plenty of aftermarket stuff that will work for either a 351W or 460. everything from k-members to motor plates. if the streets where you live require emissions testing, you may want to proceed with caution with the 460...less room in the engine compartment for front dress but it can be done...i agree with burns, do whatever rocks your boat! 460w/c6 much greater weight/cost than 351Ww/any tranny. cheers, garsten
Old Nov 29, 2005 | 06:15 PM
uuranium's Avatar
uuranium
you might consider a 351 with a junk yard turbo setup. just a thought.
merc460
Nov 8, 2002 10:09 AM
the law
Sep 6, 2002 01:14 PM
fatherford
Mar 10, 2002 04:58 PM
1911bronco
Jul 10, 2001 10:58 PM
mike460
Mar 30, 2001 07:23 AM
