Marine 460
Old Nov 29, 2005 | 03:04 PM
robert collison's Avatar
robert collison
Marine 460
I have a chance to get a 460 out of a 76 jet boat to put in my 80 f250 that has a 300 at this time.Is this engine somewhat compatible being a marine engine or will I have to change heads or have other surprises.
Thanks
Fat250
Old Nov 29, 2005 | 03:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Nov 29, 2005 | 06:43 PM
ken75ranger's Avatar
ken75ranger
The motor and heads should be fine. You will want a different cam though. Carb will probably need to be switched too. Most marine carbs have no choke at least not anything you recognize as a choke. Some use an enrichment system. If it a real screamer of a jet it might have a car carb in it.
Old Nov 29, 2005 | 07:33 PM
stevef100s's Avatar
stevef100s
How many boats have you owned? I've worked on hundreds of boats with a carb, and they all have chokes. Most came with a Quadrajet, and the choke is either electric, or operates by a heat sensing spring.
Old Nov 29, 2005 | 09:30 PM
HT32BSX115's Avatar
HT32BSX115
It appears that stevef100s might be correct.
My 87 FourWinns has an OMC King Cobra 7.5L (Ford) engine and the manual indicates that it has an automatic choke installed.
It does not however have a vacuum advance distributor. You might need an automotive distributor. The cam is also optimized for marine use ..... That also might be a factor.
dragogt
23
Sep 1, 2007 04:00 PM
whd507
Apr 1, 2005 09:55 AM
Bubba Blue
Jan 24, 2005 03:23 PM
paulm
Jan 11, 2005 06:53 AM
Fordication
Jun 18, 2004 10:12 PM
