Questions changing out 92 EFI 460 with 70's carburated 460
I recently purchased a E350 Box van that had an EFI 460 in it. I have a factory rebuilt 70's 460 (carburated). I would like to use the old 460 and put it into the box van using the EFI setup. Any suggestions from anyone, or will it even work ? Anything that I should look for ?
Welcome Did you try doing a search on this subject as this has been talked about in one form or another many times before.I am pretty certian that the efi intake will not fit on the earlier heads as the intake ports are shaped different. Eric
I did some searching last night after I posted this and found a bit of information. From what I gather, I should be able to swap out the heads & intake. Then hopefully everything should be ok after that.
Thanks for the reply. I just hope that it is that easy.
junkyardjeff
12-12-2016 09:13 PM
merc460
10-24-2002 01:58 PM
fatherford
03-10-2002 04:58 PM
