Engine Swaps
Old Jan 26, 2002 | 08:29 PM
bigtoe's Avatar
bigtoe
Engine Swaps
I have a 1979 F250 with a C6 auto trans. Right now the engine is a 460. How difficult is it to swap in a 302 or a 351?
Old Jan 26, 2002 | 09:07 PM
MGT351's Avatar
MGT351
Engine Swaps
You can get motor mounts for the application to fit the 302 or 351 since they were both offered that year, the C6 will have to be changed, You will need a trans w/ a small block bell housing. I think the radiator will work but im not 100% sure
Old Jan 27, 2002 | 08:03 AM
jowilker's Avatar
jowilker
Engine Swaps
Tobey, The swap is pretty straight forward. I would suggest that you find a donor truck with the setup that you intend to use and and pull everything from the rear gear to the radiator. Rebuild the engine and tranny at the same time and be set to go on a new setup.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jan 28, 2002 | 09:18 PM
x_FordMan_x's Avatar
x_FordMan_x
Engine Swaps
My truck came with a 460 but the truck cought on fire so i replaced the 460 with a 351m/400 and it bolted right up to the c6 but it was a long time ago and i don't remember about the motor mounts good luck
Ford Man
Old Jan 29, 2002 | 07:38 AM
Miketnf150's Avatar
Miketnf150
Engine Swaps
Bigtoe If you truck has a 460 in it why would you want to go to a smaller motor. I have a 351m/400 and would love to have a 460 but as the old saying goes no mun no fun!!! Why not just rebuild the 460 unless you are want to get away from that gas guzzling 460?:-X23
Old Feb 21, 2002 | 10:37 PM
jogaard_78's Avatar
jogaard_78
Engine Swaps
it will be a simple bolt in with the motor mount towers changed. the tranny has to be changed to the small block bolt pattern. keep the big radiator though, it will cool a 302 or 351 easily and it should never overheat.
Old Feb 21, 2002 | 11:23 PM
4xF250's Avatar
4xF250
Engine Swaps
Old Feb 22, 2002 | 11:29 AM
79f3504x4's Avatar
79f3504x4
Engine Swaps
Why?
dpoelstra
Aug 5, 2002 10:29 AM
truckertaz
15
Apr 23, 2002 05:33 PM
vinster
Sep 14, 2001 07:52 PM
DeenHylton
May 7, 2001 08:34 PM
moe
Sep 22, 1999 10:34 AM
