engine swap
Old Jul 25, 2002 | 11:27 AM
dpoelstra's Avatar
dpoelstra
engine swap
Old Aug 4, 2002 | 04:01 PM
bulldog77's Avatar
bulldog77
engine swap
hey, i have a 85 ford f150 4x4 and the inline six is almost shot. i was wondering what v8 would be the simplest and what year engine will work. I was think 351w but i don't know how difficult this will be. It is a four speed so will the tranny and bellhousing work. how big of a problem is the wireing. Thanks
Old Aug 4, 2002 | 04:55 PM
Jimbare's Avatar
Jimbare
all alone in the world
engine swap
if yours is injected, i think the wiring all comes out in one big bundle. i am not sure because i dont mess with injected vehicles. your tranny and bellhousing will work. you will have to change motor stands and exhaust for sure. probably be a difference in clutch linkage also. motor stands from 302-351w, and 351c-400 will work for you. a donor truck would be your best bet, if you can find one where you live.
Old Aug 4, 2002 | 05:35 PM
bulldog77's Avatar
bulldog77
engine swap
thanks, it is not injected and i may have found a 351m in a 77 ford car will this work for me with changing the oil pan or will it be a rear sump.i would have to find the mounts and stuff yet though. would the wireing be ok?
Old Aug 4, 2002 | 07:03 PM
Jimbare's Avatar
Jimbare
engine swap
you will have to change the bellhousing to use the 351m. big block bolt pattern.
Old Aug 4, 2002 | 09:42 PM
bulldog77's Avatar
bulldog77
engine swap
thanks, so will the engine mounts for a 302 work for a 351and how about the radator and the brakets on the engine. i might have a truck that i could get with a blew up 302 for the parts to drop a v8 in. then i could look for a 351w to drop in. So if any of this combo would work that would be great.any help would be great.
bulldog
Old Aug 4, 2002 | 10:23 PM
Jimbare's Avatar
Jimbare
engine swap
engine brackets are different. 351w is wider than 302. rad should work ok. watch the engine year, ford changed the balance weight in i think 83-84.
Old Aug 4, 2002 | 10:30 PM
electricmaniac2's Avatar
electricmaniac2
engine swap
the ports are on the opposite sides on the I-6 and the V8 trucks...needs radiator for V8....as for wiring, all sensors except the tach are the same from what I've seen on my 2 trucks. I might be getting looney, but I'm starting to prefer my I-6 truck!
Old Aug 5, 2002 | 10:29 AM
gultar's Avatar
gultar
Post engine swap
[updated:LAST EDITED ON 05-Aug-02 AT 11:33 AM (EST)]I did an engine swap in my 81 F100. Went from a IL-6 to a 68 302 & used the manual trans 3sp w/OD. I had to buy frame extentions before the motor mounts would match up, (the 302 motor mounts set back futher) got them from local Ford dealer about $75.00. I used the radiator that I had, but had to buy new upper & lower hoses that would reach the radiator. As for the trans, I was able to use the one I had, but I did have to shorten the input shaft about 2 1/2 inches before it would bolt up. (You may want to consider a different tans before cutting the imput shaft) Don't forget to install a pilot bearing in the crank for the manual trans. The only other thing that I had to do was to purchase a new distributor for the 302 since I did not have one. I got one from Auto Zone for an 81 F100 w/302, it pluged right up to the DuraSpark ingintion system.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
