1978 F150 brake problem
Old Feb 25, 2002 | 08:17 PM
f150lariat's Avatar
f150lariat
Post 1978 F150 brake problem
The brake pedal on my son's 78 F150 doesn't come back up after stepping on the brakes. You can pull the pedal up with your foot but it won't come back up by itself.
The truck has power brakes but I didn't think it would be the booster since I can pull the pedal back up with my foot.
Could the master cylinder or possibly broken springs in the rear drum brakes cause a problem like this?
Thanks
Old Feb 25, 2002 | 08:23 PM
Vampiro's Avatar
Vampiro
master cylinder, a fluid leak somewhere. check all lines and check/fix master cylinder
Old Feb 25, 2002 | 08:29 PM
f150lariat's Avatar
f150lariat
Thanks, I forgot to mention that we already checked for leaks. It has a firm pedal. It just won't return to it's normal position. once you apply the brakes they are on firmly until you pull the pedal up.
Old Feb 25, 2002 | 08:59 PM
Mil1ion's Avatar
Mil1ion
How well are the rear brakes adjusted ?
How long has the truck been sitting without use?
Jack the truck up so the wheels are off the ground.
The whole truck preferably at the same time.
So they can all be checked at the same time without relaeasing the pedal.
I suspect NO Back Pressure from the hydralics point of view from Stuck Pistons in the W.C.'s or the Calipers.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 25, 2002 | 09:19 PM
f150lariat's Avatar
f150lariat
Dennis,
The truck only gets driven a couple of times a month. I replaced all the brake lines about 2 years ago before I gave the truck to my son.
I do not know how well the rear brakes are adjusted. He did mention that he put the emergency brake on a few months ago and the cables were rusty so the emergency brakes were stuck on after that. He had to work to get the cables loose in order to drive the vehicle. He hasn't been using the emergency brake since.
It could be that there is no back pressure in the system. However, I thought that the master cylinder would push the pedal up itself. When I have bench bled them they have always pushed back to the normal position. I guess they would have a vacuum effect when they were installed in brake system with stuck cylinders.
Thanks for your input,
Daryl
Old Feb 25, 2002 | 09:53 PM
Mil1ion's Avatar
Mil1ion
Moisture gets into the system without constant use.
Remember the old saying " Use it or lose it"?
Well it has happened to me before too.
w/Explorer Pkge.
84 Volvo DL Wagon
Old Feb 26, 2002 | 09:18 AM
parneli's Avatar
parneli
I experienced this problem and the solution was in the master cylinder. You need to find out where you're sucking air from. Hope this helps.
Old Feb 26, 2002 | 09:43 AM
thitdog's Avatar
thitdog
nflfreak43
19
May 22, 2019 10:05 AM
tndallas
Sep 15, 2015 08:14 AM
|WYG|SS
Sep 20, 2011 09:42 PM
98SVTCobra
May 19, 2011 08:09 PM
cr506
18
Apr 8, 2010 08:16 PM
