help with hard brake pedal problem
Old May 18, 2011 | 07:27 PM
98SVTCobra's Avatar
98SVTCobra
I just bought a 77 F150 with a 400. With the engine running or off the brake pedal is stiff and stays on the floor. The pedal moves slightly with engine running as if its getting some vacuum but stays close to floor and feels like pushing on a brick wall haha. The truck will stop but you have to really stand on the pedal and pull it back up with hand or foot.
Master cylinder is full, front brake pads are good, rear drums have decent shoes.
Old May 18, 2011 | 08:21 PM
VocaTexas's Avatar
VocaTexas
Sounds to me like you need a new vacuum booster. On my F-150, when the diaphragm failed I could hear it sucking air when I stepped on the brake.
Old May 19, 2011 | 08:04 AM
98SVTCobra's Avatar
98SVTCobra
I dont hear any air leaks when I press brakes but it is loud under the hood. Haha, Anyone else have thoughts on this?
Old May 19, 2011 | 08:41 AM
PA74F250's Avatar
PA74F250
I would seem to think the pedal should be off the floor even if the vaccum booster is bad.
Old May 19, 2011 | 08:09 PM
98SVTCobra's Avatar
98SVTCobra
I fixed the problem today. I started by bleeding the brakes and found lots of rust in the rear lines. I bleed to brakes several times and added new fluid.
Fords412
Jan 19, 2019 08:30 PM
Fords412
16
Nov 17, 2016 02:31 PM
CollinsCD
26
Dec 27, 2013 02:10 PM
gharr8
Mar 2, 2012 10:23 PM
99forddieseltom
Feb 29, 2012 01:26 AM
