wheel hop
Old Feb 12, 2002 | 12:58 PM
bigf150's Avatar
bigf150
wheel hop
i just put 38.5 inch tires on my truck and if you go over about 35 mph you get a VERY dangerous wheel hop. i mean its so bad it feels like the trucks about to flip, they are mudder tread. what would cause this? balence? shocks?
Old Feb 12, 2002 | 01:18 PM
FordBlue's Avatar
FordBlue
wheel hop
Is it hoping or shaking from side to side? I have seen wheel hop caused by a wheel that was out of round severly, worn out shocks and even unbalanced wheels. My Son had one that started hoping wildly and when we had the tire and wheel checked, the tire had about a gallon of water in it, and we have no idea how it got there!!!
I have also seen severe side to side shake take place that was caused by a bent wheel and some worn out drag link bushings.
Mike
Old Feb 12, 2002 | 01:58 PM
caseyatthebat1's Avatar
caseyatthebat1
wheel hop
My truck had a similar problem and what it turned out to be was the gears inside one of the hubs were damaged and caused one of the front hubs to lock in while the other was not. Did you check if your ball joints and tie rods are tight? Try putting the truck up on jackstands and spinning the tire. If it is as bad as you say, you should be able to see something wrong.
Old Feb 12, 2002 | 04:39 PM
dfisher1's Avatar
dfisher1
wheel hop
Big,
Are you hitting a pot hole or speed bump? Is there input to the suspension or is the wheel hop self perpetuating? Most big trucks do supplement suspension dampening when increasing lift and tire size. Go through the numbers and insure your front end suspension is as it should be. Inspect for bent or leaking shock and check your steering dampers for serviceability.
My way is the Highway
KingFisher
P.S. Get the front end off the ground to inspect it!
Old Feb 12, 2002 | 04:50 PM
bigf150's Avatar
bigf150
wheel hop
I just mounted the tires on the rims today so i dont think that there could be water in it unless there was a lot of water in the compressor. They are not balenced but i didnt think they would hop that bad if they wernt balenced. It seems to happen just on its own and somtimes if you hit a small bump.
Old Feb 12, 2002 | 05:04 PM
FE427TP's Avatar
FE427TP
wheel hop
>My Son had one that
I've heard of using water as a poor mans balance method before since it will actually help balance the tire at speed through centrifugal force or something
Old Feb 12, 2002 | 09:18 PM
DantheMan's Avatar
DantheMan
wheel hop
Yes, I've heard that one done to. But tractors cannot go fast because the fluid for weight will come over the top of the rim, and in some cases throw them in the ditch. And that's below 30mph! So that's not the best way. I've also heard the spray-with-silicone-mount-drive-100mph way too.
Mike, with 38.5 tires you must have some kind of a lift right?
It could be a possibility you're not running enough shocks or too small of shocks to hold up to the added height of the tires.
-Dan
Old Feb 13, 2002 | 08:36 AM
73Custom's Avatar
73Custom
wheel hop
[font color=red size=2]I would bet balancing the tires would take care of it. I've lost a wheel weight on my stock sized tires, and I get a terrible shake, imagine if it was a tire THAT big... I would got get them spinbalanced, they would also be able to detect a defective tire or rim. If it just started when you put on the new tires then it's something with the tires/rims.
Marty
Old Feb 14, 2002 | 10:13 AM
rc351w's Avatar
rc351w
wheel hop
Old Feb 26, 2002 | 12:09 PM
jalampi's Avatar
jalampi
wheel hop
Ck for a cracked main leaf spring at the spring hanger.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
Mike SVOR
Oct 17, 2007 09:05 AM
fisher1995
Mar 9, 2007 10:28 AM
Squiggy
Dec 5, 2004 08:08 AM
warmdye
Jun 26, 2002 09:22 PM
Vampiro
Mar 24, 2002 09:47 PM
