ford 351m/400
Old Nov 16, 2005 | 09:23 PM
dazedrodeo's Avatar
dazedrodeo
Unhappy ford 351m/400
Well guys I need help. I just got a 1976 f-150 ranger xlt 4x4 nice all around it's an eye catcher. The org. owner died old lady kept it for a few years since 2001.ffice:office" /><O:p></O:p>
Well the guy did some work on it but the old lady didn't know what. She did say that he had changed the eng. but to what she did not know. Well to make a long story I got it for $800.<O:p></O:p>
<O:p></O:p>
The truck has a 351m/400 indicated by the casting #, off. Aluminum intake dual port, 600 cfm Holley carb new I just got it 2 weeks ago.<O:p></O:p>
<O:p></O:p>
Now the problem starts up fine with good oil pressure but when the truck heats up to operating temp. The oil pressure goes down more than I like. Then the truck starts to run a little hot. two days ago the truck started sounding like **** I think that due to the fact that it was running hot it fouled up the plugs. Also checked the timing and it was about 30 advanced so I moved it back to about 12 since I do not have the right specs.<O:p></O:p>
<O:p></O:p>
Can you all help.<O:p></O:p>
<O:p></O:p>
Old Nov 16, 2005 | 09:28 PM
yield2s's Avatar
yield2s
I think you need it retarded by 12
Old Nov 17, 2005 | 06:10 AM
dazedrodeo's Avatar
dazedrodeo
so is it 12B or 12A?
Old Nov 17, 2005 | 07:29 AM
yield2s's Avatar
yield2s
I'm sayin Im almost poss it need to be at 12*btdc
BTW You know advanced timing will cause your overheating problem, right?
Old Nov 17, 2005 | 05:57 PM
dazedrodeo's Avatar
dazedrodeo
Thanks yield2S
Old Nov 17, 2005 | 06:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Nov 17, 2005 | 06:51 PM
312's Avatar
312
did you have the vacuum advance unhooked when you checked.
Old Nov 17, 2005 | 07:26 PM
dazedrodeo's Avatar
dazedrodeo
I did have it unhooked.
boa74
Feb 23, 2008 10:56 PM
starwriter
Jan 28, 2008 02:12 AM
Residence
New Member Introductions
Nov 6, 2007 08:15 PM
kl67
Feb 14, 2007 05:14 AM
muleburrow
Feb 3, 2006 09:44 PM
