Np-435
Old Nov 7, 2005 | 12:36 AM
Rossta86's Avatar
Rossta86
Np-435
I have an 86 ford f-150 with np-435 transmission. The truck pops out of third gear, even if you hold it in making third gear pretty much un-usable. I posted on this before and i was told that towing the truck can do this as stated in the article below:
http://www.novak-adapt.com/knowledge/np435.htm
What i need to know, if this is the case, is it worth trying to rebuild and fix the transmission if it is fixable. Or should i just keep my eye out for an np-435. Im pretty sure i can get an np-435 for under 100 as i have found a private junkyard with a bunch of 80's ford. What would you do, and is my third gear fixable or forever gone?
Old Nov 7, 2005 | 01:29 AM
ford390gashog's Avatar
ford390gashog
a np-435 is easy to rebuild you can do it for about 50.00 in parts and a weekends worth of work
Old Nov 7, 2005 | 02:48 AM
sierraben's Avatar
sierraben
I'd do a rebuild.
It would also be a valuable learning experience.
Like Rossta86 posted, $50.00+ and a weekend of work.
JMHO
Old Nov 7, 2005 | 02:57 AM
ford390gashog
Originally Posted by sierraben
I'd do a rebuild.
JMHO
rossta????? my names gashog LOL
Old Nov 7, 2005 | 03:06 AM
sierraben's Avatar
sierraben
Opps! Sorry about that.
It's late.
I'm tired.
I meant to say ford390gashog.
Old Nov 7, 2005 | 11:20 AM
Pkupman82's Avatar
Pkupman82
I picked up a complete rebuild kit for my NP435 for $165 from Bronco Graveyard...it came with everything but new gears: bearings, bushings, seals, gaskets, thrust washers, syncro rings, everything to make the ol gear jammer shift like new. Like everyone else said... takes a good part of a weekend to get the job done. Good luck!
Old Nov 7, 2005 | 03:36 PM
sierraben's Avatar
sierraben
How did the rebuild come out?
Were there any special tools you needed to buy/rent/borrow?
Old Nov 7, 2005 | 09:07 PM
Katmandu's Avatar
Katmandu
Are the NP435 and ZF trannies interchangeable ??
Old Nov 7, 2005 | 09:11 PM
Pkupman82's Avatar
Pkupman82
The rebuild wasn't too difficult, just make sure you have a nice clean, well lit workbench or table to lay all the parts on. Just lay everything out in order as you take it apart, take your time and look at what comes in your rebuild kit, and make sure you have everything you need. Just take it one step at a time and you'll do fine. These old 4 speeds are really pretty simple to work on. I cannot recall needing any special tools, I recommend having a plastic/rubber dead blow hammer and a couple different sized brass punches on hand.
Old Nov 7, 2005 | 10:05 PM
sierraben's Avatar
sierraben
Pkupman82, cool.
Nice to know it wasn't too difficult; just incase I need to rebuild mine someday.
Old Nov 8, 2005 | 12:54 AM
Rossta86's Avatar
Rossta86
Im not so much worried about doing the rebuild my self but what worries me is in the article on the site:
it says "Improperly towing any vehicle with the NP435 transmission can cause the very prompt destruction of third gear bore and its mainshaft journal due to insufficient oiling." which i don't know if the third gear bore and its mainshaft journal can be repaired with just a "normal" rebuild kit? Does anyone know or can give me any more information on this? thanks for all the responses so far
Old Dec 27, 2005 | 01:09 PM
Rick2001's Avatar
Rick2001
A Cautionary Issue on Towing
If you must flat tow, and have a transfer case, you may set it in full neutral and place the NP435 in any gear to prevent mainshaft spin. However, note that many transfer cases themselves do not allow for flat towing.
Preferably, you may wish to disconnect the rear drive shaft. Rear axle lockout hubs may be a worthwhile addition for this reason.
We have seen and heard of a few incidents of this over the years, the worst of which producing a complete friction welding of third gear to its mainshaft.
This is one of the only quirks of the 435, and easily avoidable.
They mean haveing this vehicle towed not towing with it.
Coastal68
Jun 24, 2016 12:52 PM
T_Cooksey88
May 28, 2016 12:49 PM
crazy96863
Mar 5, 2016 08:47 PM
yellow truck
19
Feb 6, 2015 09:03 AM
KIKKUP
22
Aug 31, 2014 04:41 PM
