Sponsored by: Real Truck
Running boards/nerf bars
Old Oct 30, 2005 | 04:49 PM
jtsmith22's Avatar
jtsmith22
Everyone,
I need some help figuring out what to do with my running boards. I currently have the factory black molded plastic ones, and both sides were busted over the past two weeks while out hunting.
I was never too thrilled about the boards being anchored to the underside of the rocker panels to begin with, and now that I'll be replacing them, I'd like to find a very good set that are anchored to the frame and can take some minor abuse without breaking the first time out. I've searched the forums and have found a number of opinions about different manufacturers, but it can't tell which mount in the same location as the factory and which ones mount to the frame - even after searching the internet for more information.
So, can you give me your thoughts on which ones you like and which ones you know for sure anchor to the frame?
Thanks in advance!
Jim
Old Oct 30, 2005 | 05:56 PM
wvabeer's Avatar
wvabeer
I alway hated running boards or nerf bars for the fact of always getting mud or dirt on your pants when getting in and out of the truck unless your carful
Old Oct 30, 2005 | 11:22 PM
notawordok's Avatar
notawordok
the key to keeping your pants clean is to use the step and not drag your leg across it getting in. Use it as a step not an obsticle.
Old Oct 31, 2005 | 01:28 PM
redhawk44's Avatar
redhawk44
I've got Tough Country nerf bars. They are a little pricey (~$600 for wheel to wheel CC LB) and slow to deliver (I think they start cutting metal after you order.) They are very heavy duty and bolt to holes already in the frame. They are big and black but not pretty. Great for a work truck or off road truck, but not what you want for show.
Old Oct 31, 2005 | 01:33 PM
Mustang42's Avatar
Mustang42
I had the smitty built on my 01. They worked very nicely, bolted to the frame, and the paint never faded. I can only recommend these because that is all I have used.
Old Oct 31, 2005 | 05:06 PM
jtsmith22's Avatar
jtsmith22
Thanks for the replies - I'll check out tough country and smitybuilt.
I've had the same problem with the pants getting dirty, but better that than creases in my rocker panels.
Thanks again!!
Old Oct 31, 2005 | 08:03 PM
bryan21178's Avatar
bryan21178
Smile
i say if your going to fork over some cash pay for somthiung thats looks good check out the n-fabs they are cool and they run about 6 bills www.nfab.com
Old Nov 1, 2005 | 12:06 AM
darth_calvin's Avatar
darth_calvin
I wanted the frame mounted bars too, so I asked around and a friend at work had a set of Smittybilts on his Tahoe that bolted to the frame(He's got the stock bars on his Superduty). So that is what I ordered. They don't bolt to the frame on my truck. The only thing we can figure is that the frame on the Tahoe is a lot closer to the outside of the truck.
Matt
Old Nov 1, 2005 | 12:39 AM
JKBrad's Avatar
JKBrad
I have Ranchhand steps on my truck. they bolt directly to the frame and are not supported by the body at all. They are rock solid and they are tucked in enough that you dont drag your pants on them when you get out. They are and individual step for each door. www.ranchhand.com
Old Nov 1, 2005 | 01:59 AM
dgludwig's Avatar
dgludwig
I always thought a frame mounted unit would be more rigid than body mount types but, after having experience with both types, I'm not so sure now. I mounted some Smittybuilts to the frame of a 1998 Dodge QuadCab that I drove for several years and, although they were ok, I was never satisfied with the amount of flex I had with them (they also rusted badly after a couple of years).
On my 2005 SD, I installed a set of MAAP "Challenger" S/S steps which bolted to the pinch-welds (just as the stock Fords do that I looked at from the factory on the dealer's lot) on the body and they are rock solid.
I think the reason the frame mounted ones that I had were less rigid is because the brackets had such a long reach to the frame that they acted as a lever.
I do recommend that you look for a set that employs three brackets to a side instead of the usual two. I noticed that most of the Ford SDs from the factory were equipped with three brackets to a side but their parts department after market units were only provided with two brackets per side.
Old Nov 2, 2005 | 10:50 AM
jtsmith22's Avatar
jtsmith22
That's a good point about the distance to the frame - I hadn't considered that and it makes sense that there might be more flex there than if connected to the pinch welds. My primary function for the boards/bars is to protect the rocker panels, and second for my better half to be able to get in the truck without too much trouble.
I wasn't surprised that the plastic Ford boards failed, but I only want to do this once.
Thanks again for all of the input - I really do appreciate it!!
Old Nov 2, 2005 | 11:25 AM
bilter's Avatar
bilter
If you do end getting tube steps I highly recomend getting stainless steel. they cost a bit more but the will look good forever. I had black on my old teuck and they got all rusty lookng within 3 years.
Michael McIntyre
Apr 17, 2017 11:40 PM
Joe2005
2004 - 2008 F150
Mar 22, 2017 10:16 AM
TexasGuy001
May 30, 2013 01:23 AM
super fly
May 8, 2013 06:30 PM
06silvercrew
Dec 20, 2010 05:09 AM
