thump thump
Old Oct 30, 2005 | 02:32 PM
scar98's Avatar
scar98
thump thump
I was driving down a grid road hauling a load of 16 wood pallets on a utility trailer.I hit a hole in the road and right away I hear a continious thump thump.I unload the trailer and start to drive home which is about 15 miles.The thump thump slowly disappears.I get back in the city and can only slightly hear the noise when I turn right.Could I have nocked my drive shaft out of balance.The universal joints have less than 5000 kms on them.But they were purchased from part source.
Old Oct 30, 2005 | 10:00 PM
rhodie's Avatar
rhodie
What kind of truck do you have anyway? 2wd or 4wd? Where does the noise seem to come from?
Old Oct 30, 2005 | 10:04 PM
scar98's Avatar
scar98
noise
It's 1999 F150 4x4.The noise is coming from the back of the truck.
Old Oct 31, 2005 | 01:01 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
Was it a big hole, how fast where you going? How old are your tires? Is there any vibration when it thumps?
Old Oct 31, 2005 | 01:14 AM
scar98's Avatar
scar98
Not that big of a hole.But the noise started right after I hit the hole.Pretty loud inside the cab.Doesn't seem to have any vibration though.When I drove the truck back into the city(15 miles)the noise started to disappear.I drove it around to see if I could still hear it.It only showed up faintly When I was turniing corners.Must have something to do with the speed.The tires are Goodyear workhorses.Two years old.The noise is forsure coming from the rear drivers side.Same side that I hit the hole.I was going about 80km an hour.Not that fast.
I'm starting to think it's the rear driver side tire.Took the truck for a ride to night and only heard the noise a couple of times.Real faint,really had to listen for it.When I hit the hole in the road it was thumping really loud inside the cab.Tonight I had the window rolled down and only heard it faintly a couple of times.Have to take it in and start with having that tire balanced
Edit/Delete Message Reply With Quote Quick reply to this message
Old Oct 31, 2005 | 01:27 AM
Fordbronco69
Infidel
Is it a countinous/timed thump or is it eratic? Exp. Timed: Thump...Thump...Thump Eratic: Thump.Thump...thump..thump......thump? Is there anything loose in the bed? Is see theres a tool box in your pictures, might have knocked that loose. Jack the truck up on the side and try to shack the tire where the sound is coming from.
Old Oct 31, 2005 | 08:28 AM
scar98's Avatar
scar98
thump noise
It's always been a continiuos thump thump.But know I can barely hear it.I only hear it when I'm going real slow once in a while.Some people think it's the tire out of balance.Any thoughts on that?
Old Oct 31, 2005 | 09:21 AM
Fordbronco69
Infidel
It could possibly be when you hit the bump your wheel weight fell off. Check to see if there still there.
stickyrice
May 13, 2012 11:37 AM
kirkharrod
May 8, 2009 09:16 PM
kystangbanger
Apr 7, 2009 08:47 AM
Lil' Momma
Apr 22, 2007 02:39 PM
JMACC
Jan 13, 2005 09:09 AM
