Steady "thump" at low speed
Old Apr 18, 2007 | 07:21 AM
Lil' Momma's Avatar
Lil' Momma
I have had my 2001 Expedition in many different repair shops and they can't tell me what this is.... Its a steady thump thump thump after taking off, while making low speed turns and when coming to a stop. It seems to be worse at a low speed coast. Or maybe I just cant hear it when I drive faster.
Any ideas... I have had people say "well maybe cv joints, or u joints or... "
But they never make up their minds!!!
Old Apr 18, 2007 | 01:04 PM
i1dery's Avatar
i1dery
What kind of road surface are you driving on to here this noise???
Old Apr 18, 2007 | 04:17 PM
pitrow's Avatar
pitrow
I had the same problem with mine. It almost felt like something was locking up in the rear. Actually the best way I could describe it is like you have a flat spot in the old bias ply tires. A thump, thump, thump, very regularly as you drive. I had a feeling that it was something in the rear end, since I'd had a leaking axle seal for a couple years. I did take it to the dealer to have the seals and bearings replaced (since I was just too lazy to do it myself) and I haven't noticed it since then. I think it was probably an axle bearing getting ready to lock up. Either that or the gear oil that was leaking out had contaminated the parking brake shoes to the point that they were swelling and grabbing as I drove. The tech did note that the rear brakes were in bad shape.
Old Apr 19, 2007 | 09:02 AM
Omahastro1's Avatar
Omahastro1
I had this once on a truck only once the rear u joint was going out but instead of getting loose it seased up, causing it to bind up.
Old Apr 22, 2007 | 02:39 PM
davisenvy's Avatar
davisenvy
It sounds like your wheel bearings.
Rays auto
Sep 6, 2016 10:49 PM
119er
Mar 5, 2014 06:32 AM
lemasters f100
Oct 1, 2013 09:31 PM
kystangbanger
Apr 7, 2009 08:47 AM
CanadianSmokie
Jan 27, 2009 04:42 PM
