Taking bets on Greg's dyno numbers!
I give it 389 HP and 435 TQ at the rear tires.
FTE A.D.D. Member #1, (Rapidruss is member #2), other members please assign your number in a chronological order if this applies to you. Your A.D.D supporter, for back pain and sleeping, better than pills and knife.
.....=o&o>.....
.....=o&o>.....
.....=o&o>.....
.....=o&o>.....
I saw someone else posted somewhere yesterday and made a comment about having FTE ADD
BTW, as for HP...........I forgot my little Moroso Calculator so I'm WAG'n it (pun intended: me and wagons....get it...ha ha....geez, ok....) I figure it should be 366hp starting and with some easy tuning it break the 400 mark.
well, I'm off to the dyno. Let's hope I'm back in a few hours with some good numbers and not a parts list. Based on the way it ran last week, I think it will be OK. It was real consisten on the way there and back and when making those 6 passes.
It sure did not like the cold start this morning, but that cool air should help at the dyno.
greg
greg
A bit dissapointed :-(
Well, It didn't post the numbers I was expecting. But, we have a suspect. It posted about 350 rwhp and 390 ft-lbs of torque. The power falls off sharply after 5000rpm. Lately it's been running rougher at cold starts and hot starts. It will actualy cough, sputter and die if I don't let the idle smooth out sometimes. After looking at the graph, the tech thought that my plugs needed replacing. ANd that's what Kevin (strokster) has been saying for a while. I put some AC Delco in last time, because they were convenient. And they've been in there since the motor came back together. I'll be installing some new Autolites here soon. I probably won't get back to the Dyno until next week :-(
On a good note; I only spent $25 and didn't throw a rod :-)
