Taking bets on Greg's dyno numbers!
Old 10-27-2005, 11:11 PM
Scouder's Avatar
Scouder
Scouder is offline
OK, this is for bragging rights!
I'll start the pool. I say he gets 390 HP at the rear wheels.
Everybody chime in, let's see who guesses the closest!
-Scouder
Old 10-27-2005, 11:24 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
Exactly 369hp at the wheels.
Old 10-27-2005, 11:26 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
377 at the rear which is way more than i have.lol
Old 10-27-2005, 11:56 PM
fordraceboy's Avatar
fordraceboy
fordraceboy is offline
i say 392.3 at the wheels on the initial go... then he's gonna pull the stops and bust over to 401.2 on the final pull after a tweak or two...
Old 10-28-2005, 12:33 AM
gtex's Avatar
gtex
gtex is offline
Greg's a putz. I bet he throw's a rod and goes home cryin'.
I'm thinking around 375hp and hopin' for 400hp.
Old 10-28-2005, 12:40 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
I give it 389 HP and 435 TQ at the rear tires.
FTE A.D.D. Member #1, (Rapidruss is member #2), other members please assign your number in a chronological order if this applies to you. Your A.D.D supporter, for back pain and sleeping, better than pills and knife.
.....=o&o>.....
Old 10-28-2005, 01:41 AM
gtex's Avatar
gtex
gtex is offline
I gotta be in the top 5. Just look at some of my posts in the other forums...or even in this forum.
I'm a wee bit inconstricated at the moment. But, I don't have to do anything tomorrow except blow up my $30,000 old truck.
Old 10-28-2005, 03:23 AM
RapidRuss's Avatar
RapidRuss
RapidRuss is offline
FE "Freakin Expensive"
Well let me throw my hat in the ring here..... I'll say 376hp and 430lbs of Tq..
Russ
A.D.D. Member #2
Old 10-28-2005, 04:54 AM
fordbeast_80's Avatar
fordbeast_80
fordbeast_80 is offline
405 horses 450 lbs torque.
Old 10-28-2005, 08:15 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
.....=o&o>.....
I've created a MONSTER................and didn't even realize it....
I saw someone else posted somewhere yesterday and made a comment about having FTE ADD
BTW, as for HP...........I forgot my little Moroso Calculator so I'm WAG'n it (pun intended: me and wagons....get it...ha ha....geez, ok....) I figure it should be 366hp starting and with some easy tuning it break the 400 mark.
Old 10-28-2005, 08:56 AM
gtex's Avatar
gtex
gtex is offline
well, I'm off to the dyno. Let's hope I'm back in a few hours with some good numbers and not a parts list. Based on the way it ran last week, I think it will be OK. It was real consisten on the way there and back and when making those 6 passes.
It sure did not like the cold start this morning, but that cool air should help at the dyno.
greg
Old 10-28-2005, 10:04 AM
gtex's Avatar
gtex
gtex is offline
A bit dissapointed :-(
Well, It didn't post the numbers I was expecting. But, we have a suspect. It posted about 350 rwhp and 390 ft-lbs of torque. The power falls off sharply after 5000rpm. Lately it's been running rougher at cold starts and hot starts. It will actualy cough, sputter and die if I don't let the idle smooth out sometimes. After looking at the graph, the tech thought that my plugs needed replacing. ANd that's what Kevin (strokster) has been saying for a while. I put some AC Delco in last time, because they were convenient. And they've been in there since the motor came back together. I'll be installing some new Autolites here soon. I probably won't get back to the Dyno until next week :-(
On a good note; I only spent $25 and didn't throw a rod :-)
Old 10-28-2005, 10:12 AM
Mike G's Avatar
Mike G
Mike G is offline
I understand that a bottle of brown contents can clear that up....
--Mike
Old 10-28-2005, 10:17 AM
RapidRuss's Avatar
RapidRuss
Greg I just dont see how you made less with more? 360rehp last and 416lbs of Tq..
and 350 rwhp and 390lbs of Tq. I hope your ran it with track shoes on? or did ya run it with street tires as a comparison?
Russ
Old 10-28-2005, 10:20 AM
Scouder's Avatar
Scouder
Scouder is offline
Then I say bets are still on. We'll just keep throwing our bets in until next week and see what you get. You know anybody with a bigger carb? It would be fun to test after you get a good number with the one you have.
-Scouder
Quick Reply: Taking bets on Greg's dyno numbers!
