headers and transmission cooling lines
Old Oct 27, 2005 | 12:23 PM
wintremute's Avatar
wintremute
Hi all.
I just installed headers on my 77 302 c4. On the passenger side the header was rubbing the transmission cooling lines, so I've tried bending them out of the way some. I can only get them about 1/2" away from the header. Is this enough clearance? Any suggestions on what to do here like heat shielding maybe?
Thanks.
Old Oct 27, 2005 | 12:30 PM
fyrrmann's Avatar
fyrrmann
I have the same problem with mine. What I have been told is to cut them and install rubber lines to get them out of the way. Havnt done it yet though.
Old Oct 27, 2005 | 12:57 PM
wintremute's Avatar
wintremute
have you noticed any tranny issues with the fluid being hotter?
Old Oct 27, 2005 | 01:58 PM
stevef100s's Avatar
stevef100s
This will work, but there is unexpensive hose which is rubber with a braided stainless steel coating. Heting up your fluid is heating up your transmission. Heat = Death to a transmission. A good aftermarket cooler is the single best thing to do to increase the life of your auto tranny.
Old Oct 28, 2005 | 07:49 AM
wintremute's Avatar
wintremute
Any suggestions for a temporary fix? WIll heat shield tape work?
Old Oct 28, 2005 | 06:41 PM
stevef100s's Avatar
stevef100s
I doubt it very much. Since the tape is touching the line, most of the heat will be passed right through the tape. Please don't make yourself sorry by not fixing it correctly ASAP. I've wasted too much money in the past by trying temporary repairs. I've learned my lesson. I mean, crap. How the -ell much money does a little hose cost?
dwrestle
19
Mar 31, 2010 11:36 PM
sleep_deprived129
Sep 20, 2008 09:14 AM
snagmaster86
Aug 22, 2005 10:36 PM
ford390gashog
May 17, 2005 06:12 PM
Hausladen
Exhaust Systems
May 4, 2004 08:03 PM
