transmission cooling line.....help!
Old Aug 22, 2005 | 01:00 PM
snagmaster86's Avatar
snagmaster86
Unhappy transmission cooling line.....help!
I just installed a set of hooker headers on my 79 f-250. In the process of cutting through the old exhaust, the transmission cooling line met the business end of my sawzall. It didn't cut in very far but far enough to make some problems for me Now when i start the truck there is a flood of transmission fluid that comes spewing out of the line. Any ideas on how to fix it without replacing the entire line?
Old Aug 22, 2005 | 01:05 PM
bpete's Avatar
bpete
Measure the size of the line ( outside diameter) go to the hardware or parts store & tell them what you did. Ask for a compression fitting the size you measured. Go home cut trans line completely into ( a tubing cutter would work best -- no filings to end up in your transmission) slide nut onto line slide ferrel onto line & tighten down repeat with other end of fitting & line. Problem solved.
Old Aug 22, 2005 | 02:53 PM
JoeBlow's Avatar
JoeBlow
Or....
Get some rubber hose and some clamps and put it back together.
Old Aug 22, 2005 | 03:10 PM
ford390gashog's Avatar
ford390gashog
or replace the whole thing. it is just brake line. napa sells it for 8.00 a piece.
Old Aug 22, 2005 | 06:29 PM
dynamic's Avatar
dynamic
you could go all out and replace the line with a stainless steel replacement line... will never rot on you that way ... But could still meet the same fate as your old line did... damn sawsall.... lol...
Old Aug 22, 2005 | 10:36 PM
snagmaster86
so basically I should cut it the rest of the way and add some kind of tubing in where the cut is. I'll see if I can do it without creating any more problems for myself. Thanks for the help.
lm987
Dec 13, 2012 02:31 PM
smashclash
Dec 6, 2010 06:16 PM
98expeditionXLT
Oct 31, 2008 06:22 AM
jomo924
1978 - 1996 Big Bronco
Sep 10, 2008 06:41 AM
Eric Mowrer
Feb 21, 2004 10:36 PM
