headers and transmission cooling lines
Hi all.
I just installed headers on my 77 302 c4. On the passenger side the header was rubbing the transmission cooling lines, so I've tried bending them out of the way some. I can only get them about 1/2" away from the header. Is this enough clearance? Any suggestions on what to do here like heat shielding maybe? Thanks. |
I have the same problem with mine. What I have been told is to cut them and install rubber lines to get them out of the way. Havnt done it yet though.
have you noticed any tranny issues with the fluid being hotter?
I have the same problem with mine. What I have been told is to cut them and install rubber lines to get them out of the way. Havnt done it yet though. |
Any suggestions for a temporary fix? WIll heat shield tape work?
WIll heat shield tape work? |
