Header Help!
Old Sep 18, 2008 | 01:58 PM
sleep_deprived129's Avatar
sleep_deprived129
Header Help!
I just got headers on my truck. 302 with a C4. And my transmission cooling lines are in direct contact with the passenger side header. Has anyone else run into this problem? What did you do? or does anyone just have ideas as to what I can do?
Old Sep 19, 2008 | 07:49 AM
Freightrain's Avatar
Freightrain
Bend the lines away or get some spark plug boot insulators and put over line where it's touching. Better then nothing.
Old Sep 20, 2008 | 01:24 AM
sleep_deprived129
Do you think it would be a good idea to replace the lines with rubber ones(ones meant for tranmission coolers of course) in the places that I need to get away from the header?
Also, new problem has arised, it would appear that from the 'projected path' my header would appear to run me right into the crossmember for the transmission. Should I just get a pipe that will bend down then go straight to the back? or any other suggestions?
Old Sep 20, 2008 | 09:14 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Sleep_deprived129
I ran in to this problem for over 20 something years and here is how I ( Solved ) this common problem!
https://www.ford-trucks.com/user_gal...=79912&width=2
P.S. You may want to search my old post about headers, it should help a lot! I have had
pipes bent to go over, and also under, they always seemed to rattle on that crossmember!
Wally Womack
mad103
13
Feb 7, 2016 12:57 PM
F-250 restorer
Aug 28, 2015 02:17 PM
Nseal1996
Apr 2, 2013 12:12 AM
steisler
Modular V10 (6.8l)
46
Apr 24, 2009 09:10 PM
Brintiff
Exhaust Systems
Aug 4, 2005 05:05 PM
