94 ranger screech
Old Oct 27, 2005 | 01:54 AM
jnutzhorn's Avatar
jnutzhorn
94 ranger screech
I have a '94 Ranger XLT manual 5 speed, 2.3L w/136,000 miles on it. The other day it started making a screeching noise between 15mph - 25mph, its at the top end of first gear and second gear. It goes away once I shift from first to second, and then at the top end of 2nd it starts doing the same thing. At first I thought it might be my muffler coming lose or vibrating, because it is almost of high pitched vibration. Its hard to explain noises in words. But I checked my muffler and it didnt seem to be lose anywhere. It doesn't make the noise when its in neutral either, because I rev the engine up pretty high and it doesn't make the noise. Its sounds like its coming from behind the cab possibly right side. If anyone can make sense of what I just said and offer suggestions I would appreciate it. Thanx
Old Oct 27, 2005 | 07:36 AM
jimw411's Avatar
jimw411
If your truck has a 2 piece drive shaft i would suspect the carrier bearing. Other then that, Possibly A u-joint or something in the transmission. I'd start by checking your fluid level and giving everything in the drive line a shake to see if anything is loose.
Old Oct 27, 2005 | 10:24 AM
big6-87bronco's Avatar
big6-87bronco
My brother's 95 mazda had the same noise. I thought that it was a u-joint going bad but there was some sort of hard plastic cover or dust shield where the driveshaft meets the rear axle housing that was making the noise, I am not sure what it is called. I am not sure if the ranger has the same cover but it is worth looking in to.
Old Oct 27, 2005 | 08:09 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
IHateCommieCars
May 24, 2015 05:31 PM
ripstar1
1997 - 2003 F150
Sep 24, 2013 08:10 PM
CoreLokt
Jul 1, 2013 12:03 PM
cwh82
Oct 30, 2003 04:04 AM
