Loud Screeching Noise From Rear End?
Hey guys. I finally got my belt problem figured out and fixed and now this. I just noticed it today. It doesn't seem to be when I press on the brakes hard it just seems to have something to do with the rear of my truck when i gently apply the brakes. It doesn't happen every time though I was only able to get it to make the noise 3 times. Any idea what might be causing this? It's a pretty loud screech noise. Its really sharp sounding. Its hard to describe but it doesn't sound like a wear indicator on disc brakes its a good bit louder. It sounds like it is coming from the rear drivers side.
Go to the parts store and get a drum brake hardware kit for it. It will have springs and adjusting mechanism parts, and should be less than $10. On my old Ranger, the adjusting lever came loose and rubbed a pretty good groove in my drum before I could get around to fixing it, so I'd recommend doing this sooner than later.
Way back with my first truck ('85 F-250HD) I had an intermittent squealing from the rear that sometimes started/stopped when I touched the brakes. It eventually proved to be worn wheel bearings. This was a full-floater Dana 60 and the rollers were absolutely trashed (more the shape of packing peanuts than rollers). Might be something to consider if it doesn't turn out to be brakes.
berry1234
05-13-2009 04:28 PM
FutureFordOwner8
12-27-2006 07:30 PM
crazyclide
03-11-2004 12:55 PM
