turn signals shorted out
Old Oct 23, 2005 | 11:58 PM
F-150Guy's Avatar
F-150Guy
Ive been driving for about 3 months now without turn signals...its prbly time i fix em...they shorted out a while ago, but someone had a 20 amp fuse instead of a 15, so it didnt protect the circuit to well. Where should i look next for the short? its an 81 f-100, thanks
Old Oct 25, 2005 | 07:43 PM
superfast's Avatar
superfast
i know for my 80 f100, i have to turn the ignition backwards one click after i start it up for the blinkers and air to work.
Old Oct 25, 2005 | 08:56 PM
F-150Guy's Avatar
F-150Guy
Our dodge dakota does that, but these have actually shorted out. My brother said it might be the blinker relay...Anyone know anything about this?
Old Oct 26, 2005 | 08:17 AM
Holmesuser01's Avatar
Holmesuser01
Thumbs up
I'd hate to be behind you on the road with no signals. You are a rolling wreck waiting to happen.
You have a blown fuse. If you install a new one, does it blow as soon as you turn on the ignition, or does it wait until you actually try to use the signals?
Crawl under the truck and look at the wires around the back of the bed. Has anyone added trailer wires? I've been amazed at how sloppy some guys are with their improvements.
There is no flasher "relay" on these trucks.
Old Oct 26, 2005 | 11:16 AM
Bdox's Avatar
Bdox
If it blows a 20 amp fuse it sounds like a dead short. Check for mods and correct sloppy work. If nothing there, look at individual light fixtures for damage or serious corrosion.
Old Oct 26, 2005 | 04:21 PM
lmadore's Avatar
lmadore
The flasher relays are in the fuse box.
Turn signal is visible from the front of the box. (Aluminum / round)
Remove the fuse panel and turn it over, the other relay on the back is for the Hazards.
It is usually good to replace both if one is bad. They are cheap
One bad can cause turns signal and hazards not to operate properly.
SAE Customs
Sep 29, 2009 09:32 PM
ccent
Bronco II
Mar 10, 2004 10:48 AM
ford1967
Jan 16, 2004 12:46 PM
erik_herrling
1997 - 2003 F150
Jul 18, 2003 01:27 PM
erik_herrling
Electrical Systems/Wiring
Jul 18, 2003 09:29 AM
