I have a 1967 f100 short bed stepside with a 352 in it. I would really appreciate it if some one would tell me were I could find the turn signal flasher thank you
Your turn signal flasher unit should be mounted to the back of the dash cluster assembly. Remove the spedo cable and pull the gauge cluster out, careful not pull any wiring loose.
